[gdal-dev] gdal_retile error
christian.mueller at nvoe.at
Tue Mar 8 03:13:52 EST 2011
Perhaps a problem with the file permissions ?
After creating the tiles for level 0, the utility wants to create a
subdir called "1" and store the tiles for level 1 in this subdir.
Check this with your user. Make
mkdir 1
cd 1
touch test.tif
rm test.tif
Quoting Vasile Craciunescu <vasile.craciunescu at gmail.com>:
> Dear all,
> I'm trying to create tiled pyramids levels with gdal_retile.py. The
> input is a 441671px x 311892px VRT collection (1615 JPEG compressed
> GeoTiff files). The command is presented bellow:
> gdal_retile.py -levels 8 -ps 2048 2048 -r bilinear -v -co "TILED=YES"
> -co "BLOCKXSIZE=256" -co COMPRESS=JPEG -s_srs EPSG:31700 -targetDir pt
> merge.vrt
> This runs smoothly for a while (I manage to create 4151 tiles from
> level 0). Then throws the following error:
> ERROR 1: TIFFOpen:2479.tif: Operation not permitted
> Traceback (most recent call last):
> File "/usr/bin/gdal_retile.py", line 1001, in <module>
> sys.exit(main(sys.argv))
> File "/usr/bin/gdal_retile.py", line 911, in main
> dsCreatedTileIndex = tileImage(minfo,ti)
> File "/usr/bin/gdal_retile.py", line 349, in tileImage
> createTile(minfo, offsetX, offsetY, width, height,tilename,OGRDS)
> File "/usr/bin/gdal_retile.py", line 494, in createTile
> dec.uly+offsetY*dec.scaleY)
> File "/usr/bin/gdal_retile.py", line 257, in getDataSet
> t_band.WriteRaster(writeOffsetX,writeOffsetY,readX,readY,data )
> File
> "/usr/local/lib/python2.6/dist-packages/GDAL-1.8.0-py2.6-linux-i686.egg/osgeo/gdal.py", line 941,
> in
> WriteRaster
> return _gdal.Band_WriteRaster(self, *args, **kwargs)
> TypeError: not a string
> After several attempts I decided to remove 2479.tif from VRT. The same
> error is displayed when gdal_retile reach the next file (2579.tif). I
> get this error on the following configuration.
> OS: Ubuntu server 10.10
> GDAL: 1.8
> Python: 2.6.5
> Hardware: Dell PowerEdge 6650; 4 x Xeon 3.00Ghz dual core; 16GB DDR
> SDRAM; 5 x 72GB SCSI + 4TB SATA
> Any clues?
> Regards,
> Vasile
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
