[gdal-dev] Polygon topology
Mike Toews
mwtoews at gmail.com
Tue Mar 8 05:08:48 EST 2011
You could use the `interiors` length in Shapely:
from osgeo import ogr
from shapely.wkb import loads
source = ogr.Open('my_polygons.shp')
layer = source.GetLayer()
feature = layer.GetNextFeature()
num = 0
while feature:
g = loads(feature.GetGeometryRef().ExportToWkb())
if g.geom_type == 'Polygon':
g.num_holes = len(g.interiors)
elif g.geom_type == 'MultiPolygon':
g.num_holes = sum([len(mp.interiors) for mp in g])
else:
raise Exception('Unexpected geom_type: '+g.geom_type)
print g.geom_type, num, 'with', g.num_holes, 'hole'+('s' if
g.num_holes != 1 else '')
num += 1
-Mike
On 8 March 2011 21:57, Simon Lyngby Kokkendorff <silyko at gmail.com> wrote:
> Hi List,
> I am using ogr via the python bindings to construct various polygons.
> Here's just a simple question, to which someone might have some input. Is
> there anyway to determine the topology, i.e. the number of holes, of a
> polygon without e.g. having to export to WKT and examining the output
> string. There doesn't seem to be any methods exposed in the bindings to do
> this directly?
> Cheers,
> Simon Kokkendorff,
> National Survey and Cadastre of Denmark
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
