[gdal-dev] GDALWarpOperation.ChunkAndWarpImage on source without CRS
Radim Blazek
radim.blazek at gmail.com
Wed Mar 9 06:25:47 EST 2011
I am using GDALWarpOperation.ChunkAndWarpImage to read data,
everything works well except when a source dataset does not have a CRS
defined. Then it crashes with
#0 GDALGenImgProjTransform (pTransformArg=0x0, bDstToSrc=1, nPointCount=84,
padfX=0xa1093f0, padfY=0xa109690, padfZ=0xa109930, panSuccess=0xa1090a0)
at gdaltransformer.cpp:1402
#1 0x01f56c6c in GDALWarpOperation::ComputeSourceWindow (this=0xbf7fd214,
nDstXOff=0, nDstYOff=0, nDstXSize=32, nDstYSize=32, pnSrcXOff=0xbf7fd12c,
pnSrcYOff=0xbf7fd128, pnSrcXSize=0xbf7fd124, pnSrcYSize=0xbf7fd120)
at gdalwarpoperation.cpp:1977
gdaltransformer.cpp:1402:
pGCPTransformArg = psInfo->pDstGCPTransformArg;
but if I grep gdal for pDstGCPTransformArg it does not seem to be set at all.
Could you please give mi a hint? The code is here and above:
http://trac.osgeo.org/qgis/browser/trunk/qgis/src/providers/gdal/qgsgdalprovider.cpp?rev=15400#L625
Radim
