[gdal-dev] Fail to build with OpenJpeg
Joaquim Luis
jluis at ualg.pt
Wed Mar 9 09:54:32 EST 2011
On 09-03-2011 02:59, Angelos Tzotsos wrote:
> Hi Joaquim,
> In order to build with OpenJpeg, you must use the unreleased version
> 2.0 of OpenJpeg.
> Try the following:
> http://code.google.com/p/openjpeg/downloads/detail?name=openjpeg_v2_alpha_0.zip
Thanks Angelos, but with this version I'm not even able to build
OpenJpeg as it hangs on CMake with this error
Could NOT find TIFF (missing: TIFF_LIBRARY TIFF_INCLUDE_DIR)
Easy to fix the above by pointing into its local libtiff directory but
compilation hangs latter on with (only first of many)
Error 1 error C2373: 'opj_stream_create' : redefinition; different
type modifiers
C:\programs\compa_libs\OpenJPEG_V2_Alpha\Development\libopenjpeg\cio.c 228
1 openjpeg
Also, since it comes with a libtif.lib it would not likely compile for
Win64 which is may main goal to try this.
Regards
Joaquim
> Regards,
> Angelos
> On 03/09/2011 03:23 AM, Joaquim Luis wrote:
>> Hi,
>> My attempt to build gdal (trunk) on Windows with OpenJpeg failed with
>> these errors
>> C:\programs\GDALtrunk\gdal\frmts>cd openjpeg && nmake /nologo /f
>> makefile.vc && cd .. || exit 1
>> cl /nologo /MD /EHsc /Ox /D_CRT_SECURE_NO_DEPRECATE
>> /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /W4 /wd4127 /wd4251 /wd4275
>> /wd4786 /wd4100 /wd4245 /wd4206 /wd4018 /wd4389 -I..\..\port
>> -I..\..\ogr -I..\..\gcore -I..\..\alg -I..\..\ogr\ogrsf_frmts
>> -IC:\programs\compa_libs\openjpeg_v1_4\libopenjpeg -DOGR_ENABLED /c
>> openjpegdataset.cpp
>> openjpegdataset.cpp
>> openjpegdataset.cpp(80) : error C2146: syntax error : missing ';'
>> before identifier 'JP2OpenJPEGDataset_Read'
>> openjpegdataset.cpp(80) : error C4430: missing type specifier - int
>> assumed. Note: C++ does not support default-int
>> openjpegdataset.cpp(80) : error C2061: syntax error : identifier
>> 'OPJ_UINT32'
>> I greped for OPJ_UINT32 in the OpenJpeg source and on GDAL's) and
>> there was no sign of it.
>> I am using openjpeg_v1_4_source_r697 as per its web site.
>> Joaquim
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110309/9907ee1a/attachment-0001.html
