[gdal-dev] Fail to build with OpenJpeg
Joaquim Luis jluis at ualg.pt
Wed Mar 9 12:11:28 EST 2011
On 09-03-2011 16:28, Tamas Szekeres wrote:
> I had to do the following tweaks in order to compile openjpegv2 from SVN.
> Index: CMakeLists.txt
> --- CMakeLists.txt    (revision 660)
> +++ CMakeLists.txt    (working copy)
> @@ -50,6 +50,7 @@
>  IF(WIN32)
>    IF(BUILD_SHARED_LIBS)
>      ADD_DEFINITIONS(-DOPJ_EXPORTS)
> +    ADD_DEFINITIONS(-DUSE_OPJ_DEPRECATED)
>    ELSE(BUILD_SHARED_LIBS)
>      ADD_DEFINITIONS(-DOPJ_STATIC)
>    ENDIF(BUILD_SHARED_LIBS)
> Index: openjpeg.h
> --- openjpeg.h    (revision 660)
> +++ openjpeg.h    (working copy)
> @@ -37,7 +37,7 @@
>      #define OPJ_API
>      #define OPJ_CALLCONV
>  #else
> -    #define OPJ_CALLCONV __stdcall
> +    #define OPJ_CALLCONV //__stdcall
>      #ifdef OPJ_EXPORTS
>          #define OPJ_API __declspec(dllexport)
>      #else
> BTW: The compiled binaries/libs/headers (including x64) are available
> to download from: http://vbkto.dyndns.org/sdk/
Thank you very much Tamas.
I guess that to build the X64 you had to point it to a X64 libtiff.lib
that you have build yourself as well?
And, sorry, which one of your files has the libs and includes?
Not this one: release-1600-x64-gdal-mapserver.zip
<http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver.zip>
perhaps this? gdal-19dev-1600-x64-core.msi
<http://vbkto.dyndns.org/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver%5Cgdal-19dev-1600-x64-core.msi>
I confess that I don't like the .msi installers because i never know
what else the they do besides installing the package.
Joaquim
> Best regards,
> Tamas
> 2011/3/9 Joaquim Luis <jluis at ualg.pt <mailto:jluis at ualg.pt>>
>     On 09-03-2011 02:59, Angelos Tzotsos wrote:
>>     Hi Joaquim,
>>     In order to build with OpenJpeg, you must use the unreleased
>>     version 2.0 of OpenJpeg.
>>     Try the following:
>>     http://code.google.com/p/openjpeg/downloads/detail?name=openjpeg_v2_alpha_0.zip
>     Thanks Angelos, but with this version I'm not even able to build
>     OpenJpeg as it hangs on CMake with this error
>     Could NOT find TIFF (missing: TIFF_LIBRARY TIFF_INCLUDE_DIR)
>     Easy to fix the above by pointing into its local libtiff directory
>     but compilation hangs latter on with (only first of many)
>     Error    1    error C2373: 'opj_stream_create' : redefinition;
>     different type modifiers
>     C:\programs\compa_libs\OpenJPEG_V2_Alpha\Development\libopenjpeg\cio.c
>     228    1    openjpeg
>     Also, since it comes with a libtif.lib it would not likely compile
>     for Win64 which is may main goal to try this.
>     Regards
>     Joaquim
>>     Regards,
>>     Angelos
>>     On 03/09/2011 03:23 AM, Joaquim Luis wrote:
>>>     Hi,
>>>     My attempt to build gdal (trunk) on Windows with OpenJpeg failed
>>>     with these errors
>>>     C:\programs\GDALtrunk\gdal\frmts>cd openjpeg && nmake /nologo /f
>>>     makefile.vc <http://makefile.vc> && cd ..   || exit 1
>>>             cl  /nologo /MD /EHsc /Ox /D_CRT_SECURE_NO_DEPRECATE
>>>     /D_CRT_NONSTDC_NO_DEPRECATE /DNDEBUG /W4 /wd4127 /wd4251 /wd4275
>>>     /wd4786 /wd4100 /wd4245 /wd4206 /wd4018 /wd4389 -I..\..\port
>>>     -I..\..\ogr -I..\..\gcore  -I..\..\alg -I..\..\ogr\ogrsf_frmts
>>>     -IC:\programs\compa_libs\openjpeg_v1_4\libopenjpeg
>>>     -DOGR_ENABLED   /c openjpegdataset.cpp
>>>     openjpegdataset.cpp
>>>     openjpegdataset.cpp(80) : error C2146: syntax error : missing
>>>     ';' before identifier 'JP2OpenJPEGDataset_Read'
>>>     openjpegdataset.cpp(80) : error C4430: missing type specifier -
>>>     int assumed. Note: C++ does not support default-int
>>>     openjpegdataset.cpp(80) : error C2061: syntax error : identifier
>>>     'OPJ_UINT32'
>>>     I greped for OPJ_UINT32 in the OpenJpeg source and on GDAL's)
>>>     and there was no sign of it.
>>>     I am using openjpeg_v1_4_source_r697 as per its web site.
>>>     Joaquim
>>>     _______________________________________________
>>>     gdal-dev mailing list
>>>     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>>     http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110309/aa560a08/attachment.html
