[gdal-dev] Re: building with PDF driver on Windows + ?
cpadwick
cpadwick at digitalglobe.com
Wed Mar 9 16:15:28 EST 2011
Hi, I've followed the instructions posted above but have run into a linker
error. Any ideas which lib I'm missing?
Thanks,
Chris
2 File(s) copied
cd ..
if exist gdal.lib del gdal.lib
lib /nologo /out:gdal.lib port\*.obj gcore\*.obj alg\*.obj
frmts\o\*.obj
ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
link /nologo /dll /INCLUDE:_OGRFeatureStylePuller
/INCLUDE:_OSRValidate
/INCLUDE:_OPTGetProjectionMethods /INCLUDE:_OGR_G_GetPointCount
/INCLUDE:_OG
RRegisterAll /INCLUDE:_GDALSimpleImageWarp at 36
/INCLUDE:_GDALReprojectImage at 48
/INCLUDE:_GDALComputeMedianCutPCT at 32 /INCLUDE:_GDALDitherRGB2PCT at 28
/INCLUDE:_
OCTNewCoordinateTransformation at 8 port\*.obj gcore\*.obj alg\*.obj
frmts\o\*.obj
C:\cgp\code\xerces\xerces-c-3.0.
1\Build\Win32\VC9\Release\xerces-c_3.lib
"C:\cgp\code\mrsid\Lidar_DSDK\li
b\lti_lidar_dsdk.lib" "C:\cgp\code\mrsid\Raster_DSDK\lib\lti_dsdk.lib"
odbc32.lib odbccp32.lib user32.lib
C:\KDE\lib\poppler.li
b C:\KDE\lib\poppler-cpp.lib C:\KDE\lib\poppler-qt4.lib
C:\KDE\lib\freetype.lib
C:\KDE\lib\lcms-1.lib advapi32.lib gdi32.lib gcore\Version.res
/out:gdal18.dll
/implib:gdal_i.lib
poppler.lib(GlobalParams.cc.obj) : error LNK2005: _DllMain at 12 already
defined in
gdaldllmain.obj
Creating library gdal_i.lib and object gdal_i.exp
poppler.lib(DCTStream.cc.obj) : warning LNK4217: locally defined symbol
_jpeg_de
stroy_decompress imported in function "public: virtual __thiscall
DCTStream::~DC
TStream(void)" (??1DCTStream@@UAE at XZ)
_jpeg_Cr
eateDecompress imported in function "private: void __thiscall
DCTStream::init(vo
id)" (?init at DCTStream@@AAEXXZ)
_jpeg_re
sync_to_restart imported in function "private: void __thiscall
DCTStream::init(v
oid)" (?init at DCTStream@@AAEXXZ)
_jpeg_st
d_error imported in function "private: void __thiscall
DCTStream::init(void)" (?
poppler.lib(JpegWriter.cc.obj) : warning LNK4049: locally defined symbol
_jpeg_s
td_error imported
_jpeg_st
art_decompress imported in function "public: virtual void __thiscall
DCTStream::
reset(void)" (?reset at DCTStream@@UAEXXZ)
_jpeg_re
ad_header imported in function "public: virtual void __thiscall
DCTStream::reset
_jpeg_re
ad_scanlines imported in function "public: virtual int __thiscall
DCTStream::get
Char(void)" (?getChar at DCTStream@@UAEHXZ)
poppler.lib(JpegWriter.cc.obj) : warning LNK4217: locally defined symbol
_jpeg_d
estroy_compress imported in function "public: virtual __thiscall
JpegWriter::~Jp
egWriter(void)" (??1JpegWriter@@UAE at XZ)
_jpeg_s
tart_compress imported in function "public: virtual bool __thiscall
JpegWriter::
init(struct _iobuf *,int,int,int,int)"
(?init at JpegWriter@@UAE_NPAU_iobuf@@HHHH at Z
_jpeg_s
imple_progression imported in function "public: virtual bool __thiscall
JpegWrit
er::init(struct _iobuf *,int,int,int,int)"
HH at Z)
_jpeg_s
et_quality imported in function "public: virtual bool __thiscall
JpegWriter::ini
(?init at JpegWriter@@UAE_NPAU_iobuf@@HHHH at Z)
_jpeg_s
et_defaults imported in function "public: virtual bool __thiscall
JpegWriter::in
_jpeg_C
reateCompress imported in function "public: virtual bool __thiscall
JpegWriter::
_jpeg_w
rite_scanlines imported in function "public: virtual bool __thiscall
JpegWriter:
:writePointers(unsigned char * *,int)"
(?writePointers at JpegWriter@@UAE_NPAPAEH at Z
_jpeg_f
inish_compress imported in function "public: virtual bool __thiscall
JpegWriter:
:close(void)" (?close at JpegWriter@@UAE_NXZ)
poppler.lib(JPEG2000Stream.cc.obj) : error LNK2019: unresolved external
symbol _
_imp__opj_destroy_decompress at 4 referenced in function "public: virtual void
__th
iscall JPXStream::close(void)" (?close at JPXStream@@UAEXXZ)
symbol _
_imp__opj_image_destroy at 4 referenced in function "public: virtual void
__thiscal
symbol _
_imp__opj_cio_close at 4 referenced in function "private: void __thiscall
JPXStream
::init2(unsigned char *,int,enum CODEC_FORMAT)"
(?init2 at JPXStream@@AAEXPAEHW4COD
EC_FORMAT@@@Z)
symbol _
_imp__opj_decode at 8 referenced in function "private: void __thiscall
JPXStream::i
(?init2 at JPXStream@@AAEXPAEHW4CODEC_
FORMAT@@@Z)
symbol _
_imp__opj_cio_open at 12 referenced in function "private: void __thiscall
JPXStream
EC_FORMAT@@@Z)
symbol _
_imp__opj_setup_decoder at 8 referenced in function "private: void __thiscall
JPXSt
ream::init2(unsigned char *,int,enum CODEC_FORMAT)"
4CODEC_FORMAT@@@Z)
symbol _
_imp__opj_set_event_mgr at 12 referenced in function "private: void __thiscall
JPXS
tream::init2(unsigned char *,int,enum CODEC_FORMAT)"
W4CODEC_FORMAT@@@Z)
symbol _
_imp__opj_create_decompress at 4 referenced in function "private: void
__thiscall J
PXStream::init2(unsigned char *,int,enum CODEC_FORMAT)"
AEHW4CODEC_FORMAT@@@Z)
symbol _
_imp__opj_set_default_decoder_parameters at 4 referenced in function "private:
void
__thiscall JPXStream::init2(unsigned char *,int,enum CODEC_FORMAT)"
(?init2 at JPX
Stream@@AAEXPAEHW4CODEC_FORMAT@@@Z)
poppler.lib(PNGWriter.cc.obj) : error LNK2019: unresolved external symbol
_png_s
et_longjmp_fn referenced in function "public: virtual bool __thiscall
PNGWriter:
(?init at PNGWriter@@UAE_NPAU_iobuf@@HHHH at Z
gdal18.dll : fatal error LNK1120: 10 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
9.0\VC\BIN
\link.EXE"' : return code '0x460'
Stop.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-building-with-PDF-driver-on-Windows-tp5635431p6155509.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
