[gdal-dev] Chinese Filenames
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 10 11:07:11 EST 2011
On 11-03-10 10:42 AM, kui yang wrote:
> gdal 1.8.0 has problem. when the filename is in Chinese
Kui Yang,
That is not a very detailed bug report. GDAL 1.8 includes some changes
in the underlying handling of filenames such that filenames passed in to
GDALOpen() should be passed in UTF-8 rather than the local encoding. This
was generally the situation already on Linux and I suppose most other unix
type operating systems. But it was a change on windows.
Are you working on windows?
How are you encoding the filenames being passed to GDALOpen()?
As a workaround, you can restore essentially the old filename handling
behavior on windows by setting the GDAL_FILENAME_IS_UTF8 configuration
variable to "NO". Some info on setting config options is available at:
http://trac.osgeo.org/gdal/wiki/ConfigOptions
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
