[gdal-dev] [OGR]Add a vertex to a feature
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Mar 11 06:24:46 EST 2011
Mohamed,
OGR's shapefile driver may not write the file to the disk until the handle
is closed.
If the data is going to me simple enough you should consider the CSV format.
http://www.gdal.org/ogr/ogr_formats.html
http://www.gdal.org/ogr/drv_csv.html
2011/3/11 Mohamed Saâd HESSANE <saad.hessane at gmail.com>
> Hy list,
> I' m trying to add on the fly points comming from GPS to a shapefile.
> But the only way i find is to delete the feature from the shapefille, and
> create a new feature with the added point. There's another way?
> Thank you
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110311/e50566b7/attachment.html
