[gdal-dev] Many files over the network
Even Rouault
even.rouault at mines-paris.org
Mon Mar 14 18:40:34 EDT 2011
Kyle,
you didn't mention which driver was in question. I guess this is GeoTIFF ?
I've looked at the code of the driver and it appears that it loads the .rpb
and .imd files at least since GDAL 1.6.0. The new thing in GDAL 1.8.0 is that
it also tries to load the _rpc.txt file. Is it that small difference which
causes the slowdown you observe ?
In fact, setting GDAL_DISABLE_READDIR_ON_OPEN = TRUE might make things
actually worse (w.r.t to that aspect of loading rpb/rpc/imd) since the driver
has to really test the filesystem to look for the existence of the files,
whereas by default it would rely on the papszSiblingsFile list.
Anyway, I've attached a patch (against SVN trunk) that differs the loading of
RPC and IMD until necessary (that is to say when GetMetadata() or
GetMetadataItem() is called with "RPC" or "IMD" metadata domain, or when
GetFileList() is called).
Could you try it and report if it makes things better for you ?
Another idea to solve the performance problem would be to use an alternate
GDALOpen() where you could provide the papszSiblingFile list. If you read
several files in the same directory, you could build the list one and provide
it multiple times afterwards.
Best regards,
Even
> Often, we need to open many raster files over a network connection with
> thousands of other files residing in the same directory.
> Previously, we were using version 1.7.0 of GDAL (from FW Tools), and we
> used SetConfigOption("GDAL_DISABLE_READDIR_ON_OPEN", "TRUE")
> to suppress the automatic search for sibling files. This approach served
> us well.
> We upgraded to 1.8.0. It was quite a bit slower opening the raster files.
> I was able to get GDAL built in debug and stepped through the code and
> discovered the following:
> 1. It searches for several files containing RPC metadata.
> 2. It searches for files for PAM as well.
> I was able to use SetConfigOption("GDAL_PAM_ENABLED", "NO") to suppress
> searching for PAM files.
> However, I do not see a way to suppress searching for RPC metadata. Does
> anyone know of a way to do this or other workarounds? If there is no way to
> currently do this, is the community open to adding this option?
> I apologize if this question has been posted previously, but I haven't yet
> found a convenient way to search the archives.
> Thanks,
> Kyle
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110314/347272a1/differ_reading_rpc_and_imd-0001.bin
