[gdal-dev] Calculate footprints of shapefiles
Marius Jigmond
mariusjigmond at hotmail.com
Tue Mar 15 20:35:59 EDT 2011
Armin,
Not sure if this would be straightforward in GDAL but you might want to
consider a combination of GDAL + Shapely
(http://gispython.org/shapely/docs/1.2/manual.html#cascading-unions).
What you're trying to do is spatial analysis not directly implemented in
GDAL. Shapely requires that you're working with Cartesian coordinates.
The upside is that it has WKT/WKB support for direct loading into
PostGIS.
-marius
On Wed, 2011-03-16 at 01:08 +0100, Armin Burger wrote:
> Hi all
> I would like to catalogue shapefiles scattered over lots of directories
> of the file system and store retrievable information of the shapefiles
> in a PostGIS layer. Extracting parameters like extent, projection,
> fields, etc works very fine with GDAL's Python bindings.
> But I would also like to store a sort of "footprint" of the whole
> shapefile as a geometry object since the extent is a bit coarse
> geographic representation of the shapefile.
> So far I have no better idea than eg. for polygon shapefiles looping
> through all features, applying a Union function on them. And at the end
> trying to use the Simplify method on the resulting polygon that will be
> used as the footprint.
> This is for sure not very efficient for larger shapefiles with lots of
> records. And for line and point shapefiles I still don't have a clue how
> their records could be represented by an enclosing polygon (maybe the
> Boundary functions does something like this...).
> Any ideas how this footprint generation could be achieved in a feasible
> way using GDAL/OGR Python?
> Cheers, Armin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
