[gdal-dev] Pickling OGR Geometry
Jason Beverage
jasonbeverage at gmail.com
Wed Mar 16 11:24:54 EDT 2011
Hi all,
I'm looking at pickling ogr geometry. I took the following code from
the gdal autotests to try it out:
geom_wkt = 'MULTIPOLYGON( ((0 0,1 1,1 0,0 0)),((0 0,10 0, 10 10, 0
10),(1 1,1 2,2 2,2 1)) )'
geom = ogr.CreateGeometryFromWkt(geom_wkt)
p = pickle.dumps(geom)
g = pickle.loads(p)
if not geom.Equal(g):
print "pickled geometries were not equal"
else:
print "pickled geometries equal"
The geometries are equal and appears to work fine but I get an error
printed out right after the loads call:
ERROR 1: Empty geometries cannot be constructed
If I do ogr.UseExceptions() I get the stack trace:
File "test.py", line 32, in <module>
g = pickle.loads(p)
File "/usr/lib/python2.6/pickle.py", line 1374, in loads
return Unpickler(file).load()
File "/usr/lib/python2.6/pickle.py", line 858, in load
dispatch[key](self)
File "/usr/lib/python2.6/pickle.py", line 1133, in load_reduce
value = func(*args)
File "/usr/local/lib/python2.6/dist-packages/GDAL-1.7.2-py2.6-linux-x86_64.egg/osgeo/ogr.py",
line 2935, in __init__
this = _ogr.new_Geometry(*args, **kwargs)
RuntimeError: Empty geometries cannot be constructed
Is this a problem or is it just noise? I'm using GDAL 1.7.2.
Thanks,
Jason
