[gdal-dev] Get pixel values from all bands
Alexander Bruy
alexander.bruy at gmail.com
Wed Mar 16 16:21:28 EDT 2011
Hi all
I work on raster processing application (developed with C++ and Qt).
For reading rasters we use GDAL and it's C++ API.
For one task we need to get pixel values from all raster bands. For
this I get all GDALRasterBands and store them in list. Then in loop
read image row by row and store row from each band in another list.
Here is simplified code
// iterate over image row by row
for ( int row = 0; row < ySize; ++row )
// read one row from each band and store it in list
for ( int b = 0; b < bandCount; ++b )
float *scanline;
scanline = (float *) CPLMalloc( sizeof( float ) * xSize );
bands[ i ]->RasterIO( GF_Read, 0, row, xSize, 1, scanline, xSize,
1, GDT_Float32, 0, 0 );
rows[ i ] = scanline;
// iterate on pixels in row
for (int col = 0; col < ySize; ++col)
// get pixel value from bands
float pixel[bandCount];
for ( int r = 0; r < bandCount; ++r )
// get value in (row, col) from band r
double pixel[r] = rows[ r ][ col ];
// do something with this pixel
Is this correct approach? Or maybe there is another more correct way
to do this?
Also I'm not sure where I should free memory allocated with CPLMalloc().
After reading pixels and before reading next rows or at end when
all rows processed?
I'm not a big C++ programmer, so any help is very appreciated
Thanks
Alexander Bruy
