[gdal-dev] Where is this nmake.opt file located?
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Mar 17 00:27:02 EDT 2011
Natasha,
After you install the GDAL and GDAL-Oracle packages, you can access the
command line applications in the OSGeo4W Shell command window.
http://trac.osgeo.org/osgeo4w/#QuickStartforOSGeo4WUsers
You can find the info on connecting to Oracle Spatial in the GDAL website.
For vector data access: http://www.gdal.org/ogr/drv_oci.html
For raster data access: http://www.gdal.org/frmt_georaster.html
On Thu, Mar 17, 2011 at 12:51 AM, natasha chatterjee <
natashachatterjee at rediffmail.com> wrote:
> Thanks
> I installed Osgeo4w but now I am not getting how to connect
> GDAL with Oracle spatial.Please tell me the process and what
> are the prerequisites to bechecked.(How to proceed?)
> Kindly help me.
> Regards
> Natasha
> Tynaks
> On Tue, 15 Mar 2011 23:57:06 +0530 wrote
> >Natasha,
> nmake.opt file is for when you compile the source. It is in the root
> directory of the GDAL source tree.
> If you intend to use Oracle Spatial with GDAL on Windows, you are better
> off with OSGeo4W than FWTools. It provides oracle support as a separate
> plugin. http://trac.osgeo.org/osgeo4w/
> On Tue, Mar 15, 2011 at 10:52 PM, natasha chatterjee wrote:
> Hi All
> I am using FWTools.Can anyone tell me where is this
> nmake.opt file located on our system?if its not there then
> how to get it?(As i want to configure oracle spatial with
> GDAL)
> please reply soon.
> Thanks and regards
> Natasha
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> <http://sigads.rediff.com/RealMedia/ads/click_nx.ads/www.rediffmail.com/signatureline.htm@Middle?>
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110317/bad577a2/attachment.html
