[gdal-dev] Open(), OpenShared(), errors, FlushCache(), and no Close() ?
Even Rouault even.rouault at mines-paris.org
Fri Mar 18 18:14:48 EDT 2011
Michal,
For a reason I'm unclear (might be just historical and not desired behaviour
?), the VRT driver will try to rewrite the VRT if it has been modified.
There's however a workaround to avoid the error to pop at the closing. You can
empty the description of the dataset with source_ds.SetDescription('')
Open() or OpenShared() will not change anything about that.
In python, you close a dataset by dropping the reference to the object, for
example by assigning None to it.
I'm not clear why you have errors with your new webserver, but if you use a
multi-threaded one, did you make sure you have built GDAL with thread support
(./configure --with-threads)  ? (This is now the default since GDAL 1.8.0)
Best regards,
Even
> Hi,
> I'm seeing some weird behaviors related to virtual raster datasets opened
> simultaneously from multiple processes. I hope I can explain so that this
> makes sense. Here's an excerpt of my python code:
> 	http://dpaste.com/hold/515217/
> Line 8 is where I make a change to the dataset:
> 	source_ds.SetProjection(source_ds.GetGCPProjection())
> I do that so that the projection for the ground control points is available
> for a later call to gdal.ReprojectImage(); it wasn't working until I
> started to use SetProjection() in this way. All of this is being called
> from the context of a multi-process web server, running as unprivileged
> user "www-data" under Ubuntu (this is important later). My web server
> error log fills up with these:
> 	ERROR 1: Failed to write .vrt file in FlushCache().
> My assumption here is that because the unprivileged user can't write to the
> dataset file, gdal throws off an error to complain that it can't flush the
> dataset cache back to the original file. So far, this is just an
> annoyance, but one that I would expect to go away when I switched from
> gdal.Open() to gdal.OpenShared() with the read-only flag, like this:
> 	gdal.OpenShared(src_path, gdal.GA_ReadOnly)
> Still getting the errors.
> Meanwhile, I made a switch in web servers, from an Apache-based CGI
> environment to the multi-worker WSGI server Gunicorn. When I initially ran
> my code under Gunicorn using my normal, privileged user account, I
> immediately started to see failures from gdal.Open and gdal.OpenShared,
> specifically the assertion errors on line 4 of the dpaste above. I tried
> to place exclusive file locks (using fcntl.flock) around each access to a
> given VRT dataset, but this didn't seem to help at all. There were
> frequent, unpredictable errors with opening data sets in a multi-process
> environment *until* I switched from the privileged user to the
> unprivileged user. Once I did that, everything began to work normally, but
> I got all the old "ERROR 1" reports again.
> It seems to me that gdal.OpenShared() with the read-only flag isn't doing
> what it promises, and that it's trying to write back to the files,
> potentially modifying them even as competing processes are accessing them.
> Is it possible that the overlapping processes in my privileged user
> scenario are seeing temporarily-empty VRT files? I'm also confused by the
> lack of a gdal.Close() function or something similar, and by the fact that
> I can't seem to make a change to a dataset in memory without gdal
> attempting to push that change back to disk via FlushCache().
> What's the right thing to do here? Make temporary copies of small VRT data
> sets prior to each use so they can be safely written to and disposed of?
> Build a wrapper class that encapsulates copying and disposal? Figure out
> some way to make gdal release datasets when asked, or open them in real
> read-only mode?
> Any advice greatly appreciated!
> -mike.
> michal migurski- mike at stamen.com
>                  415.558.1610
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
