[gdal-dev] Does WMS TMS minidriver support a local path for
<ServerURL>?
Jeff Ruby
jgr007 at gmail.com
Mon Mar 21 16:03:50 EDT 2011
I get the same result if I use file://c:/temp/7/0/0
I've also every permutation I can think of, but none seemed to work.
BTW, I'm trying run gdal_translate:
gdal_translate my.xml my.tif
I don't think I mentioned that previously.
Thanks much for your responses, Even.
On Mon, Mar 21, 2011 at 3:48 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Le lundi 21 mars 2011 20:42:37, Jeff Ruby a écrit :
>> Hmmm...it doesn't seem to work for me. I get the following error:
>> 0ERROR 1: GDALWMS: Unable to download block 0, 0.
>> URL: file:///c:/temp/7/0/0
>> HTTP status code: 0, error: Couldn't open file /c:/temp/7/0/0.
> --> The error message shows that it tries to open "/c:/temp/7/0/0", note the
> leading slash. The reason is your URL below where you have the 2 slashes of
> file:// plus one additional slash. Try removing it.
>> ERROR 1: IReadBlock failed at X offset 0, Y offset 0
>> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
>> All my tiles are in c:\temp. Below is my xml file:
>> <GDAL_WMS>
>> <Service name="TMS">
>> <ServerUrl>file:///c:/temp/${z}/${x}/${y}</ServerUrl>
>> <SRS>EPSG:32618</SRS>
>> </Service>
>> <DataWindow>
>> <UpperLeftX>224270.0</UpperLeftX>
>> <UpperLeftY>3731360.0</UpperLeftY>
>> <LowerRightX>226811.0</LowerRightX>
>> <LowerRightY>3728689.0</LowerRightY>
>> <SizeX>25088</SizeX>
>> <SizeY>26624</SizeY>
>> <TileCountX>49</TileCountX>
>> <TileCountY>52</TileCountY>
>> <TileLevel>7</TileLevel>
>> </DataWindow>
>> <Projection>EPSG:32618</Projection>
>> <BlockSizeX>25088</BlockSizeX>
>> <BlockSizeY>26624</BlockSizeY>
>> <BandsCount>3</BandsCount>
>> <Cache/>
>> </GDAL_WMS>
>> On Fri, Mar 18, 2011 at 4:11 PM, Even Rouault
>> > Le vendredi 18 mars 2011 21:00:12, Jeff Ruby a écrit :
>> >> Hi,
>> >> I've built a TMS structure using gdal2tiles. I'd like to access the
>> >> files directly not via a webserver.
>> >> It appears the WMS TMS minidriver may be an option and I'd like to
>> >> know if <ServerURL> supports reference to a local drive\path.
>> > Yes, use file://a_directory_name
>> >> Thanks much,
>> >> -Jeff
>> >> _______________________________________________
>> >> gdal-dev mailing list
>> >> gdal-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
