[gdal-dev] accessing zip files by URL
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Mar 24 13:30:57 EDT 2011
Joaguim,
I think /vsizip/vsicurl/http://path.to/the/file.zip works.
You have to initialize the zip file and remote file handlers using
VSIInstallCurlFileHandler() and VSIInstallZipFileHandler()
Refer: http://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip
On Thu, Mar 24, 2011 at 8:48 PM, Joaquim Luis <jluis at ualg.pt> wrote:
> Hi,
> How do we access to a compressed files by URL? We can do that, can't we?
> As an example I try this (on Windows)
> gdalinfo /vsizip/C:\
> http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.dem.zip
> ERROR 4: `/vsizip/C:\
> http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.dem.zip'
> does not exist in the file system,
> and is not recognised as a supported dataset name.
> and this
> gdalinfo /vsizip//
> but the error message is similar.
> The idea is to fetch the data directly into GMT, but first I need to
> understand well how it works.
> Thanks
> Joaquim Luis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110324/9a1823c7/attachment.html
