[gdal-dev] accessing zip files by URL
Joaquim Luis
jluis at ualg.pt
Thu Mar 24 14:03:57 EDT 2011
Even, Chaitanya
Thanks for hint.
I did read the http://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip but it
hasn't any mention to the need of using "vsicurl"
I was about to do the tests you did, so thank you also for that.
The point here is not to read that file in particular. I just wanted to
use one as example and one that is not a *.tar.gz that the docs say it
won't work.
Ok, I have enough information to make it possible to read some
compressed files sitting somewhere in the web and have the data land
directly in the internals of GMT.
Thanks
Joaquim
> Joaquim,
> The correct syntax would be :
> gdalinfo
> /vsizip/vsicurl/http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.dem.zip/W020N90.DEM
> or just :
> gdalinfo
> because the zip file only contains one single file (W020N90.DEM)
> ... But the W020N90.DEM inside the zip file isn't directly recognized by GDAL
> (even if you download it and unzip the file). It's just a RAW file, that neads
> an header to tell the dimension, georeferencing, datatype etc, so the above
> won't directly work.
> You can for example create a VRT that refers to the raw file :
> <VRTDataset rasterXSize="4800" rasterYSize="6000">
> <GeoTransform>-20, 8.3333333333300008e-03, 0, 90, 0,
> -8.3333333333300008e-03</GeoTransform>
> <VRTRasterBand dataType="Int16" band="1" subClass="VRTRawRasterBand">
> <NoDataValue>-9999</NoDataValue>
> <SourceFilename
> relativetoVRT="0">/vsizip/vsicurl/http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.dem.zip</SourceFilename>
> <ByteOrder>MSB</ByteOrder>
> </VRTRasterBand>
> </VRTDataset>
> I've deduced this VRT from the
> http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.hdr.zip file that
> sits next to the .dem.zip file.
> It's a shame that they didn't put the .hdr and the .dem file inside the same
> zip. It would have they been possible to open it directly...
> With the SRTM3 in HGT format, you can directly do :
> gdalinfo
> /vsizip/vsicurl/http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Africa/N00E006.hgt.zip
> Best regards,
> Even
>> Hi,
>> How do we access to a compressed files by URL? We can do that, can't we?
>> As an example I try this (on Windows)
>> gdalinfo
>> /vsizip/C:\http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.de
>> m.zip ERROR 4:
>> `/vsizip/C:\http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.d
>> em.zip' does not exist in the file system,
>> and is not recognised as a supported dataset name.
>> and this
>> gdalinfo
>> /vsizip//http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.dem.
>> zip
>> but the error message is similar.
>> The idea is to fetch the data directly into GMT, but first I need to
>> understand well how it works.
>> Thanks
>> Joaquim Luis
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
