[gdal-dev] accessing zip files by URL
Joaquim Luis jluis at ualg.pt
Thu Mar 24 14:21:32 EDT 2011
Great, thanks
Joaquim
> Le jeudi 24 mars 2011 19:03:57, Joaquim Luis a écrit :
>> Even, Chaitanya
>> Thanks for hint.
>> I did read the http://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip but it
>> hasn't any mention to the need of using "vsicurl"
> Yes I am aware that it is lightly documented. I've added recently a few
> pointers though :
> - in the GDALOpen() doc :
> http://gdal.org/gdal_8h.html#e97be045eb4701183ad332ffce29745b
> which points to :
> http://gdal.org/cpl__vsi_8h.html#4f791960f2d86713d16e99e9c0c36258
> Which mentions :
> "This special file handler can be combined with other virtual filesystems
> handlers, such as /vsizip. For example,
> /vsizip//vsicurl/path/to/remote/file.zip/path/inside/zip"
> Perhaps a more didactic page would be needed in the wiki. Any taker :-) ? I
> remind that the wiki is open in writing for everyone with an osgeo id...
>> I was about to do the tests you did, so thank you also for that.
>> The point here is not to read that file in particular. I just wanted to
>> use one as example and one that is not a *.tar.gz that the docs say it
>> won't work.
> Ah... well actually reading in a .tar or a .tar.gz is now supported (
> http://gdal.org/cpl__vsi_8h.html#d6dd983338849e7da4eaa88f6458ab64 ). Seems
> that I have changed my mind since. But seeking will still be very slow of
> course (especially if you combine with /vsicurl !). Ok, I'm going to rectify
> the page about that point.
>> Ok, I have enough information to make it possible to read some
>> compressed files sitting somewhere in the web and have the data land
>> directly in the internals of GMT.
>> Thanks
>> Joaquim
>>> Joaquim,
>>> The correct syntax would be :
>>> gdalinfo
>>> /vsizip/vsicurl/http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w02
>>> 0n90.dem.zip/W020N90.DEM
>>> or just :
>>> gdalinfo
>>> 0n90.dem.zip
>>> because the zip file only contains one single file (W020N90.DEM)
>>> ... But the W020N90.DEM inside the zip file isn't directly recognized by
>>> GDAL (even if you download it and unzip the file). It's just a RAW file,
>>> that neads an header to tell the dimension, georeferencing, datatype
>>> etc, so the above won't directly work.
>>> You can for example create a VRT that refers to the raw file :
>>> <VRTDataset rasterXSize="4800" rasterYSize="6000">
>>>     <GeoTransform>-20, 8.3333333333300008e-03,  0,  90,  0,
>>> -8.3333333333300008e-03</GeoTransform>
>>>     <VRTRasterBand dataType="Int16" band="1" subClass="VRTRawRasterBand">
>>>       <NoDataValue>-9999</NoDataValue>
>>>       <SourceFilename
>>> relativetoVRT="0">/vsizip/vsicurl/http://dds.cr.usgs.gov/srtm/version2_1/
>>> SRTM30/w020n90/w020n90.dem.zip</SourceFilename>
>>>       <ByteOrder>MSB</ByteOrder>
>>>     </VRTRasterBand>
>>> </VRTDataset>
>>> I've deduced this VRT from the
>>> http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.hdr.zip
>>> file that sits next to the .dem.zip file.
>>> It's a shame that they didn't put the .hdr and the .dem file inside the
>>> same zip. It would have they been possible to open it directly...
>>> With the SRTM3 in HGT format, you can directly do :
>>> gdalinfo
>>> /vsizip/vsicurl/http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Africa/N00E0
>>> 06.hgt.zip
>>> Best regards,
>>> Even
>>>> Hi,
>>>> How do we access to a compressed files by URL? We can do that, can't we?
>>>> As an example I try this (on Windows)
>>>> gdalinfo
>>>> /vsizip/C:\http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90
>>>> .de m.zip ERROR 4:
>>>> `/vsizip/C:\http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n9
>>>> 0.d em.zip' does not exist in the file system,
>>>> and is not recognised as a supported dataset name.
>>>> and this
>>>> gdalinfo
>>>> /vsizip//http://dds.cr.usgs.gov/srtm/version2_1/SRTM30/w020n90/w020n90.d
>>>> em. zip
>>>> but the error message is similar.
>>>> The idea is to fetch the data directly into GMT, but first I need to
>>>> understand well how it works.
>>>> Thanks
>>>> Joaquim Luis
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
