[gdal-dev] Issue with Configure for cross compiling GDAL and make
PradeepKumar Penchala
pradeepkumar.penchala at iiitb.net
Tue Mar 29 14:10:44 EDT 2011
Hello,
When I am running make command, I am getting some errors at the end of its
execution:
make[1]: Entering directory `/home/gise/Desktop/Pradeep/gdal-1.8.0/apps'
/bin/sh /home/gise/Desktop/Pradeep/gdal-1.8.0/libtool --mode=link g++
gdalinfo.lo /home/gise/Desktop/Pradeep/gdal-1.8.0/libgdal.la -o gdalinfo
libtool: link: g++ .libs/gdalinfo.o -o .libs/gdalinfo
/home/gise/Desktop/Pradeep/gdal-1.8.0/.libs/libgdal.so -Wl,-rpath
-Wl,/external/gdal/lib
/home/gise/Desktop/Pradeep/gdal-1.8.0/.libs/libgdal.so: undefined reference
to `png_read_info at PNG12_0'
to `png_get_tRNS at PNG12_0'
to `png_set_PLTE at PNG12_0'
to `png_get_text at PNG12_0'
to `png_set_packing at PNG12_0'
to `png_write_rows at PNG12_0'
to `png_set_error_fn at PNG12_0'
to `png_get_image_width at PNG12_0'
to `png_get_interlace_type at PNG12_0'
to `png_read_rows at PNG12_0'
to `png_set_IHDR at PNG12_0'
to `png_set_write_fn at PNG12_0'
to `png_write_end at PNG12_0'
to `png_get_bit_depth at PNG12_0'
to `png_create_read_struct at PNG12_0'
to `png_read_image at PNG12_0'
to `png_get_channels at PNG12_0'
to `png_create_write_struct at PNG12_0'
to `png_get_color_type at PNG12_0'
to `png_write_info at PNG12_0'
to `png_get_PLTE at PNG12_0'
to `png_destroy_write_struct at PNG12_0'
to `png_get_image_height at PNG12_0'
to `png_set_compression_level at PNG12_0'
to `png_destroy_read_struct at PNG12_0'
to `png_error at PNG12_0'
to `inflateCopy at ZLIB_1.2.0'
to `png_set_read_fn at PNG12_0'
to `png_set_tRNS at PNG12_0'
to `png_create_info_struct at PNG12_0'
to `png_sig_cmp at PNG12_0'
collect2: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: Leaving directory `/home/gise/Desktop/Pradeep/gdal-1.8.0/apps'
make: *** [apps-target] Error 2
Can you please help me out in resolving this issue.
Thanks and Regards,
Pradeep
GISE Lab,
IIT Bombay
9769598197
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110329/bb14fe29/attachment-0001.html
