R: Re: [gdal-dev] create kml file using MySQL database or shape file
sigfrido at tiscali.it sigfrido at tiscali.it
Wed May 4 06:08:40 EDT 2011
Hi Murat,
I'm not so much into KML, but I think that maybe the
problem is with your SQL: you are not including any geometry column in
the select instruction. If you open the KML file with a text editor,
you can see if the points are being exported and with which
coordinates.
Does the MySQL table have a geometric column? Or you just
have the lon/lat coordinates?
If you don't have geometry you have first
to add it to the MySQL table, update it with the point geometry created
from lon/lat, and then export the points in KML.
Hope this helps
Sig
----Messaggio originale----
Da: beyhan at deprem.gov.tr
Data: 04/05/2011
9.17
A: "Luca Sigfrido Percich"<sigfrido at tiscali.it>
Cc: "gdal-
dev at lists.osgeo.org"<gdal-dev at lists.osgeo.org>
Ogg: Re: [gdal-dev]
Dear Sigfrido,
Thank you for your help,
I corrected the script and it works but when I
open it with google-earth
points doesn't seem on the map I sent
snapshot of the google-earth.I
think problem is latitude and longitude
could not read by the
google-earth.
So How can I fix it...
Regards.
ogr2ogr -f KML sisint.kml
MySQL:'afetler,host=localhost,user=root,
password=mysql_123,port=3306,tables=sisint' -sql "SELECT koy,
longitude, latitude , sisint from sisint"
koy means village name.
sisint menans seismic intensity value of the village
Murat
On Tue,
2011-05-03 at 17:33 +0200, Luca Sigfrido Percich wrote:
> Hi Murat,
> Il giorno mar, 03/05/2011 alle 16.57 +0300, Murat Beyhan ha scritto:
> > ogr2ogr -f KML simgmt.kml simgmt.shp -dsco NameField=RegionName
this can create a file but strangely data collected at one point.
Probably it is a Spatial Reference System related problem: you should
specify the source shapefile SRS. Have a look at the KML file and see
if
> the points have different coordinates, and see what SRS has been
declared for it. Have a look at the -a_srs, -t_srs and -s_srs options
of
> ogr2ogr.
> > ogr2ogr -f KML sisint.kml MySQL
:'host=localhost user=root
> > password=mysql_pswd port=3306
dbname=afetler tables=sisint' -sql "SELECT
> > latitude,longitude,
sisint from sisint"
> Try with no space between MySQL and :, and
specifying the database name
> before any other option:
> ogr2ogr -f
KML sisint.kml
password=mysql_pswd,port=3306,tables=sisint' -sql "SELECT latitude,
longitude,sisint from sisint"
> All the best
> Sig
Murat BEYHAN
Geophysical Engineer, M.Sc.
Prime Ministry
Disaster and
Emergency Management Presidency
Earthquake Department
Address:
Eskisehir Yolu 12. Km.
Lodumlu/ANKARA
Tel: 312 2872680-1556
email:
This message has been scanned for viruses
and
dangerous content by MailScanner, and is
believed to be clean.
Non temiamo alcun confronto: Tiscali ha l'Adsl più veloce d'Italia!
Risparmia con Tutto Incluso Light: Voce + Adsl 20 mega a soli 17,95 € al mese per 12 mesi.
http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/?WT.mc_id=01fw
