[gdal-dev] Registering GDAL 1.8 64-bit with Python 2.7 on Windows 7
Gregory Yetman gyetman at ciesin.columbia.edu
Wed May 4 14:59:55 EDT 2011
I'm pulling my hair out over what should be a simple problem. I'm trying
to use the pre-compiled GDAL library and bindings published here:
http://vbkto.dyndns.org/sdk/PackageList.aspx?file=release-1400-x64-gdal-1-8-mapserver-5-6.zip
To implement a pure 64-bit Python and GDAL combo (I already have numpy
64-bit working with python 2.7 64-bit).
GDAL is working on on the system, gdalinfo --version returns:
GDAL 1.8.0, released 2011/01/12
and python works fine as well. I installed the bindings with no error
messages and rebooted, but if I try and import gdal I get:
 >>> from osgeo import gdal
   File "<stdin>", line 1, in <module>
   File "C:\Python27\Lib\site-packages\osgeo\__init__.py", line 21, in
<module>
     _gdal = swig_import_helper()
   File "C:\Python27\Lib\site-packages\osgeo\__init__.py", line 17, in
swig_import_helper
     _mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: DLL load failed: The specified module could not be found.
I created a PYTHONPATH system variable and set it to:
C:\Python27\Lib\site-packages;C:\Python27\Lib\site-packages\osgeo;C:\Program
Files\GDAL
to no avail.
Any suggestions?
I'm trying to get the 64 bit versions working because when I try and
open a large raster as an array using
DatasetReadAsArray I get an error; suggestions on another mailing list
were that this was because the 32 bit library can only handle rasters up
to 2GB and the ones I am working with are larger than that.
TIA,
Greg
Gregory Yetman
CIESIN, Columbia University
+1-845-365-8982
http://www.ciesin.columbia.edu
