[gdal-dev] Re: python memory driver
Juliannerc juliannerc at gmail.com
Thu May 5 12:18:29 EDT 2011
I believe that I have the example working.  When using the command 'print
an_array', it wasn't showing the parts that contained non-zero data.  Once I
realized that, everything seems to work as expected.
Thanks for the support.
Julianne
View this message in context: http://osgeo-org.1803224.n2.nabble.com/python-memory-driver-tp6332439p6334776.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
