[gdal-dev] Re: Ogr tutorial code in cpp not compiling due to
	errors
    Chaitanya kumar CH
    chaitanya.ch at gmail.com
    Fri May  6 02:17:34 EDT 2011
Pradeep,
I have seen your screenshots.
No wonder you got the multiple declaration errors, with all the
'unterminated #ifndef' and '#endif without #if" errors. You should try to
identify the source of those errors.
I never compiled GDAL/OGR files separately from the source tree. Check if
you get the same errors if you compile the whole source tree.
http://trac.osgeo.org/gdal/wiki/BuildHints
You can use the compiled libraries after setting the LD_LIBRARY_PATH and
GDAL_DATA environment variables to 'gdal' and 'gdal/data' directory paths.
In the future you can use sites like http://pastebin.com/ to share text with
others.
On Fri, May 6, 2011 at 11:07 AM, PradeepKumar Penchala <
pradeepkumar.penchala at iiitb.net> wrote:
> Please find the attached screenshots. Now they should open.
> On Fri, May 6, 2011 at 11:01 AM, Chaitanya kumar CH <chaitanya.ch@
> gmail.com> wrote:
>> Pradeep,
>> I still can't open your screenshots file. (Did you resend the same file?)
>> On Fri, May 6, 2011 at 10:30 AM, Pradeepkp <
>>> Hello Chaitanya,
>>> ogr_core.h is present in the same directory where .cpp is present. Gdal
>>> files, you mean the header files which are required right, I have included
>>> all of them and are present in the same directory.
>>> Thanks and Regards,
>>> Pradeepkp
>>> On Fri, May 6, 2011 at 10:22 AM, Chaitanya kumar CH [via OSGeo.org] <[hidden
>>> email] <http://user/SendEmail.jtp?type=node&node=6336487&i=0&by-user=t>>wrote:
>>>> Pradeep,
>>>> I see your ogr_core.h file is in a separate directory. Are you compiling
>>>> ogr without the gdal files?
>>>> Also, I couldn't open the screenshots archive.
>>>>  On Fri, May 6, 2011 at 9:33 AM, Pradeepkp <[hidden email]<http://user/SendEmail.jtp?type=node&node=6336472&i=0&by-user=t>
>>>> > wrote:
>>>>> Hello,
>>>>> While I am compiling the code (cpp version) given in
>>>>> http://www.gdal.org/ogr/ogr_apitut.html
>>>>> I am getting lot of compilation errors. I am not sure why they are
>>>>> coming as
>>>>> it is the code directly taken from the above given link. Can you please
>>>>> look
>>>>> at the screenshots attached and let me know if I am making any mistakes
>>>>> in
>>>>> running.
>>>>> These are few sample errors:
>>>>> Code:
>>>>> 318: enum ogr_style_tool_param_pen_id
>>>>> 319:{
>>>>> 320:    OGRSTPenColor       = 0,
>>>>> 321:    OGRSTPenWidth       = 1,
>>>>> 322:    OGRSTPenPattern     = 2,
>>>>> 323:    OGRSTPenId          = 3,
>>>>> 324:    OGRSTPenPerOffset   = 4,
>>>>> 325:    OGRSTPenCap         = 5,
>>>>> 326:    OGRSTPenJoin        = 6,
>>>>> 327:    OGRSTPenPriority    = 7,
>>>>> 328:    OGRSTPenLast        = 8
>>>>> 330:  };
>>>>>  332: enum ogr_style_tool_param_brush_id
>>>>>  333: {
>>>>>  334:    OGRSTBrushFColor    = 0,
>>>>>  335:    OGRSTBrushBColor    = 1,
>>>>>  336:    OGRSTBrushId        = 2,
>>>>>  337:    OGRSTBrushAngle     = 3,
>>>>>  338:    OGRSTBrushSize      = 4,
>>>>>  339:    OGRSTBrushDx        = 5,
>>>>>  340:    OGRSTBrushDy        = 6,
>>>>>  342:    OGRSTBrushPriority  = 7,
>>>>> http://osgeo-org.1803224.n2.nabble.com/file/n6336405/screenshots_errors.tar.gz<http://osgeo-org.1803224.n2.nabble.com/file/n6336405/screenshots_errors.tar.gz?by-user=t&by-user=t>
>>>>>  343:    OGRSTBrushLast      = 8
>>>>>  344:
>>>>>  345: };
>>>>> /home/pradeep/android maps/Ogr Tutorial/ogr_core.h:328: error:
>>>>> conflicting
>>>>> declaration ‘OGRSTPenLast’
>>>>> ‘OGRSTPenLast’ has a previous declaration as
>>>>> ‘ogr_style_tool_param_pen_id
>>>>> OGRSTPenLast’
>>>>> /home/pradeep/android maps/Ogr Tutorial/ogr_core.h:332: error: multiple
>>>>> definition of ‘enum ogr_style_tool_param_brush_id’
>>>>> /home/pradeep/android maps/Ogr Tutorial/ogr_core.h:332: error: previous
>>>>> definition here
>>>>> View this message in context:
>>>>> http://osgeo-org.1803224.n2.nabble.com/Ogr-tutorial-code-in-cpp-not-compiling-due-to-errors-tp6336405p6336405.html<http://osgeo-org.1803224.n2.nabble.com/Ogr-tutorial-code-in-cpp-not-compiling-due-to-errors-tp6336405p6336405.html?by-user=t&by-user=t>
>>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> [hidden email]<http://user/SendEmail.jtp?type=node&node=6336472&i=1&by-user=t>
>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> /tʃaɪθənjə/ /kʊmɑr/
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>>>> [hidden email]<http://user/SendEmail.jtp?type=node&node=6336472&i=2&by-user=t>
>>>>  If you reply to this email, your message will be added to the
>>>> discussion below:
>>>> http://osgeo-org.1803224.n2.nabble.com/Ogr-tutorial-code-in-cpp-not-compiling-due-to-errors-tp6336405p6336472.html<http://osgeo-org.1803224.n2.nabble.com/Ogr-tutorial-code-in-cpp-not-compiling-due-to-errors-tp6336405p6336472.html?by-user=t>
>>>>  To unsubscribe from Ogr tutorial code in cpp not compiling due to
>>>> errors, click here.
>>> Thanks and Regards,
>>> Pradeep
>>> GISE Lab,
>>> IIT Bombay
>>> 9769598197
>>> *screenshots_errors.tar.gz* (2M) Download Attachment<http://attachment/6336487/0/screenshots_errors.tar.gz?by-user=t>
>>> View this message in context: Re: Ogr tutorial code in cpp not compiling
>>> due to errors<http://osgeo-org.1803224.n2.nabble.com/Ogr-tutorial-code-in-cpp-not-compiling-due-to-errors-tp6336405p6336487.html>
>>> Sent from the GDAL - Dev mailing list archive<http://osgeo-org.1803224.n2.nabble.com/GDAL-Dev-f2022644.html>at Nabble.com.
>>> gdal-dev at lists.osgeo.org
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
> Thanks and Regards,
> Pradeep
> GISE Lab,
> IIT Bombay
> 9769598197
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110506/a3ea66af/attachment-0001.html
