[gdal-dev] RFC 35: Delete, reorder and alter field definitions of OGR layers - Call for discussion
Stephen Woodbridge woodbri at swoodbridge.com
Mon May 9 11:00:22 EDT 2011
On 5/9/2011 7:54 AM, Martin Dobias wrote:
> Hi Even
> On Sat, May 7, 2011 at 7:16 PM, Even Rouault
> <even.rouault at mines-paris.org>  wrote:
>> Hi,
>> I've written a new RFC to add the capability to delete fields, reorder fields
>> and alter field definitions, in OGR layer definitions.
>>         http://trac.osgeo.org/gdal/wiki/rfc35_deletereorderalterfielddefn
> Thanks a lot for creating the RFC.
> I have just two comments:
> - is the alternation of hte field definition going to have some rules
> how the existing data should be converted to the new type or will the
> driver itself choose how to convert the data? The latter option is
> surely the easier one, but it would be probably good to guarantee at
> least some expected conversions: int<->  text, float<->  text, round
> the number when lowering precision etc.
> - what is actually the motivation behind reordering of the fields? Is
> that just for aesthetical reasons? (e.g. zip code should be next to
> the city name)
Martin,
On rationale, it that some programs, like mapserver, require that all
files in a tile index have identical attribute column definitions. This
means same column names, types, widths and column ordering.
In other cases, I do prefer to keep some columns grouped together rather
than just randomly tacked on to the end so i would use this if it were
available.
Regards,
   -Steve
