[gdal-dev] gdal_array not found in Python
Gregory Yetman
gyetman at ciesin.columbia.edu
Mon May 9 15:51:44 EDT 2011
I've installed GDAL 1.8 and have it (mostly) working with Python 2.7.1.
I can import all modules from osgeo except gdal_array. There is a
gdal_array.py file in the site-packages directory with the other modules.
I'm using the binaries (for windows) from here:
http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-x64-gdal-1-8-mapserver-5-6.zip
I get the error message below only when I try and import gdal_array:
>>> from osgeo import gdal_array
File "<stdin>", line 1, in <module>
File "C:\Python27\lib\site-packages\osgeo\gdal_array.py", line 24, in
<module>
_gdal_array = swig_import_helper()
File "C:\Python27\lib\site-packages\osgeo\gdal_array.py", line 16, in
swig_import_helper
import _gdal_array
ImportError: No module named _gdal_array
I have numpy installed, not sure if that's a requirement or not. Any
suggestions would be appreciated!
TIA,
Greg
Gregory Yetman
CIESIN, Columbia University
+1-845-365-8982
http://www.ciesin.columbia.edu
