[gdal-dev] Setting "INIT_DEST" to nan on windows
Kyle Shannon
ksshannon at gmail.com
Mon May 9 17:30:05 EDT 2011
Thanks Even,
If that is the case, are there other values in psWarpOptions I *have* to
set? I can't find docs discussing that.
kss
* Kyle Shannon
* ksshannon at gmail.com
On Thu, May 5, 2011 at 12:21, Even Rouault <even.rouault at mines-paris.org>wrote:
> Le mercredi 04 mai 2011 00:40:42, Kyle Shannon a écrit :
> > I am using AutoCreateWarpedVRT to warp a dataset. I grab the the source
> > nodata for a band using
> > double noData = poBand->GetNoDataValue( &pbSuccess );
> > which returns 1.#QNAN00000000... on windows.
> > I then try to set the INIT_DEST with this using
> > psWarpOptions->papszWarpOptions =
> > CSLSetNameValue( psWarpOptions->papszWarpOptions,
> > "INIT_DEST", CPLSPrintf( "%lf", noData ) );
> > This works on linux when it returns nan(0x8000000000000), but not on
> > windows, is there a different string I need to set in the warp options?
> Those NaN values are generally a nighmare to deal with...
> But a quick look at :
> const char *pszInitDest = CSLFetchNameValue(
> psOptions->papszWarpOptions,
> "INIT_DEST" );
> if( pszInitDest != NULL && !EQUAL(pszInitDest, "") )
> char **papszInitValues =
> CSLTokenizeStringComplex( pszInitDest, ",", FALSE, FALSE );
> int nInitCount = CSLCount(papszInitValues);
> for( iBand = 0; iBand < psOptions->nBandCount; iBand++ )
> double adfInitRealImag[2];
> GByte *pBandData;
> const char *pszBandInit =
> papszInitValues[MIN(iBand,nInitCount-1)];
> if( EQUAL(pszBandInit,"NO_DATA")
> && psOptions->padfDstNoDataReal != NULL )
> adfInitRealImag[0] = psOptions->padfDstNoDataReal[iBand];
> adfInitRealImag[1] = psOptions->padfDstNoDataImag[iBand];
> else
> CPLStringToComplex( pszBandInit,
> adfInitRealImag + 0, adfInitRealImag +
> 1);
> Make me believe that one way is to assign the value(s) of the
> padfDstNoDataReal[] array of psWarpOptions with the noData (NAN) value and
> set
> INIT_DEST to the "NO_DATA" string.
> > Thanks.
> > * Kyle Shannon
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110509/3bd19f12/attachment.html
