[gdal-dev] GDAL 1.8.0 and MrSid "no-data" values
Oyvind Idland oyvind.idland at gmail.com
Fri May 13 05:27:48 EDT 2011
I just updated to 1.8.0 from 1.7, using the MrSid DSDK 8.0.
In order to handle transparency, i have until now used the metadata values
from "IMAGE__NO_DATA_VALUE",
and simply masked away pixels.
After upgrading, the IMAGE__NO_DATA_VALUE yields nothing, neither is it
listed when using gdalinfo.
The band->GetNoDataValue() doesn't give me any hints either.
Should I handle this in a different way ?
-- Oyvind
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110513/ac9f53cc/attachment.html
