[gdal-dev] Using gdal to generate thumbnails
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri May 13 11:53:00 EDT 2011
António,
You can use the gdal_translate utility with the -outsize option. But you may
require the original dimensions to maintain the aspect ratio. You can grab
the dimensions from the output from the gdalinfo utility.
http://www.gdal.org/gdalinfo.html
http://www.gdal.org/gdal_translate.html
2011/5/13 António Rocha <antonio.rocha at deimos.com.pt>
> Greetings
> I have a couple of Gtif Images and I want to create thumbnails. Is it
> possible to do that with GDAL?
> Thanks
> Antonio
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature database 6119 (20110513) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110513/e0506668/attachment.html
