[gdal-dev] Creating mosaic larger than 4GB using gdal_merge.py
Vytas
vytas at dendron.com
Fri May 13 14:03:50 EDT 2011
Using gdal_merge.py to merge multiple Geotif files and get the
following error? Is there a work around to the size issue? Expected
output file size is about 12 Gigs. I was under the impression gdal was
able to handle Big TIFF format. If not, can you please suggest a
format available in Gdal that I can use which will support large rasters?
gdal_merge.py -o tot.tif Port*.tif
ERROR 6: A 53888 pixels x 35904 lines x 3 bands UInt16 image would be
larger than 4GB
but this is the largest size a TIFF can be. Creation failed.
Creation failed, terminating gdal_merge.
Thanks,
Vytas
