[gdal-dev] Labeling rasters
Jerl Simpson jsimpson at wxtrends.com
Mon May 16 16:08:16 EDT 2011
Ok, thank you.
Does anyone else have any suggestions?
On Mon, May 16, 2011 at 3:06 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com> wrote:
> Jerl,
> I'm afraid gdal_rasterize can't do the labelling. You will need a
> specialized renderer for that. I'm not familiar with any of the desktop
> applications that do this. Perhaps, qgis has a plugin.
> On Tue, May 17, 2011 at 1:30 AM, Jerl Simpson <jsimpson at wxtrends.com> wrote:
>> I already have the resultant image, it looks great.   Just drawing
>> lines on a map.  I'm using a blank image so I can more clearly see
>> what's going on.  It's just a black and white image, and that's all I
>> want.
>> I'm trying to get the contour labeled, so I know which one I'm
>> viewing.  So on the 1000 contour, I should see 1000 on the line
>> somewhere, and if it's a 547 contour, I should see 547 on the line
>> somewhere.
>> Is that possible?
>> Thanks,
>> Jerl
>> On Mon, May 16, 2011 at 2:41 PM, Chaitanya kumar CH
>> > Jerl,
>> > The contour attribute and the Z values are same here. Just one of them
>> > is
>> > enough.
>> > With the Z values near the magnitude of 1000, the burn value of 255 is
>> > not
>> > going to make much of a difference. Use it if you want to offset any
>> > negative Z values.
>> > You should mention contour.shp instead of just 'contour' for
>> > <src_datasource>.
>> > Make sure BLANK.tif doesn't have different extents/projection.
>> > Your final image will have a data type of Float64. You may have to run
>> > some
>> > contrast stretching operations on it.
>> > On Tue, May 17, 2011 at 12:04 AM, Jerl Simpson <jsimpson at wxtrends.com>
>> > wrote:
>> >> Hi guys and gals:
>> >> I have something that's evading me.  I have a basic ESRI Shape file
>> >> (created using gdal_contour) that I run through gdal_rasterize to
>> >> generate very nice looking contour map.  But I want the value of the
>> >> contour in there.
>> >> I've been trying different things with the -a option, but I can't get
>> >> it to work out.
>> >> Here's the latest thing I've tried for gdal_rasterize:
>> >> gdal_rasterize -a contour -3d -b 1 -b 2 -b 3 -b 4 -burn 255 -burn 255
>> >> -burn 255 -burn 255 -burn 255 -l contour contour BLANK.tif
>> >> I put an extra burn value in there (have also tried with out) to see
>> >> if maybe it was just going in as 0.  BLANK.tif is just a black image.
>> >> I'm sure I'm missing something simple, just can't see it.  I thought
>> >> the -a would burn the value of "contour" into the raster.
>> >> Thanks for any guidance!!
>> >> Here's the data from my shapefile:
>> >> INFO: Open of `contour/'
>> >>      using driver `ESRI Shapefile' successful.
>> >> Layer name: contour
>> >> Geometry: 3D Line String
>> >> Feature Count: 157
>> >> Extent: (-0.500000, -89.830132) - (359.500000, 89.144137)
>> >> Layer SRS WKT:
>> >> GEOGCS["GCS_WGS_1984",
>> >>    DATUM["WGS_1984",
>> >>        SPHEROID["WGS_1984",6378137,298.257223563]],
>> >>    PRIMEM["Greenwich",0],
>> >>    UNIT["Degree",0.017453292519943295]]
>> >> contour: Real (12.3)
>> >> OGRFeature(contour):0
>> >>  ID (Integer) = 0
>> >>  contour (Real) =     1000.000
>> >>  LINESTRING (87.765060240963862 80.0 1000,.....
>> >> _______________________________________________
>> >> gdal-dev mailing list
>> >> gdal-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> > Best regards,
>> > Chaitanya kumar CH.
>> > /tʃaɪθənjə/ /kʊmɑr/
>> > +91-9494447584
>> > 17.2416N 80.1426E
>> This communication is privileged and may contain confidential
>> information.  It's intended only for the use of the person or entity
>> named above. If you are not the intended recipient, do not distribute
>> or copy this communication. If you have received this communication in
>> error, please notify the sender immediately and return the original to
>> the email address above. © Copyright 2011 Weather Trends
>> International, Inc.
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
International, Inc.
