[gdal-dev] ERDASJP2 Debug builds crash
Frank Warmerdam
warmerdam at pobox.com
Tue May 31 09:15:05 EDT 2011
On 11-05-31 07:20 AM, Emmet Spier wrote:
> All,
> I have been trying to build GDAL with ECWJP2 support. I have built a test
> program using exactly the same build environment (vc80) and flags as the gdal
> default gdal build enviroment. In Debug builds in or out of the debugger I
> experience a crash in the ERDAS (debug) dll on GDALClose(). Below I include
> full details demonstrating the vanilla test carried out.
> If anyone could offer thoughts on what I might be doing wrong I would be very
> grateful.
> Emmet.
> I build gdal 1.8 using "nmake /f makefile.vc DEBUG=1" having set the ECW
> variables in nmake.opt
> ------- BUILD EXTRACT FOLLOWS SHOWING 'Default' DEBUG BUILD ----------
> D:\ThirdPartyBuilds\GDAL\yagb\gdal-1.8.0\frmts>cd ecw && nmake /nologo /f
> makefile.vc && cd .. || exit 1
> cl /nologo /MD /EHsc /Zi /W4 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_NO_DEPRECATE /Fd..\..\gdal18.pdb /DDEBUG -I..\..\port
> -I..\..\ogr -I..\..\gcore -I..\..\alg -I..\..\ogr\ogrsf_frmt
Emmet,
To the best of my knowledge adding DEBUG=1 to the build does not use the
windows debug runtime, it just builds with /Zi (turn on debug information).
So I presume the runtime choices are not compatible with a debug runtime
build of the ECW SDK.
I normally do not build GDAL with the debug runtime but if you really want
to you are likely going to have adjust the flags yourself.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
