[gdal-dev] Clipping multi-polygons shapefiles with Geometry.Intersection . Any help to fix out my method?
Brent Fraser bfraser at geoanalytic.com
Tue May 31 09:40:18 EDT 2011
It may help to supply a small test dataset that causes the problem.
Best Regards,
Brent Fraser
On 5/31/2011 1:28 AM, hajer wrote:
> No idea about this issue??
> Thanks for help !
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Clipping-multi-polygons-shapefiles-with-Geometry-Intersection-Any-help-to-fix-out-my-method-tp6410874p6421682.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
