[gdal-dev] Convert from CA83-VF (EPSG 2229) to WGS84 (EPSG 4326) using gdaltransform
Jean-Claude Repetto jrepetto at free.fr
Tue May 31 15:33:20 EDT 2011
On 05/31/11 21:23, kavinmehta wrote:
> Hi,
> I would like to convert a shape file from EPSG 2229 to EPSG 4326 but am not
> too sure how to do this using gdaltransform and running it from the command
> line?
> gdaltransform -s_srs "c:\xyz\oldfile.shp" -t_srs "c:\xyz\newfile.shp"
> but it did not work.
The appropriate utility to reproject shapefiles is ogr2ogr :
http://www.gdal.org/ogr2ogr.html
Jean-Claude
