[gdal-dev] Re: Convert from CA83-VF (EPSG 2229) to WGS84 (EPSG 4326) using gdaltransform
kavinmehta kavin at tsswireless.com
Tue May 31 17:51:02 EDT 2011
Thanks Frank. Would you know how to do it? i.e. what command to use to
convert a shape file from (EPSG 2229) to (EPSG 4326). I am having a hard
time doing it thru ogr2ogr however i can easily do this in FME Desktop tool
which uses ogr2ogr internally.
Thanks,
kavin Mehta.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Convert-from-CA83-VF-EPSG-2229-to-WGS84-EPSG-4326-using-gdaltransform-tp6424186p6424722.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
