[gdal-dev] Kakadu Jpeg2000 driver
Even Rouault even.rouault at mines-paris.org
Tue Nov 1 07:59:45 EDT 2011
Selon Livneh Yehiyam <yehil at rafael.co.il>:
> Hi
> Is it possible to build the JP2KAK driver as a plugin?
You didn't mention on which OS you want to build it, but I have had a look at
both makefiles, and I don't see any existing support for building as a plugin.
However, I don't foresee any obvious reason why you this would not doable,
provided that you can tweak the makefile.
> Thanks
> Yehiyam
