[gdal-dev] to make black triangle transparent (gdalwarp)
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Nov 3 06:49:24 EDT 2011
Jan,
The -dstalpha option should have created the alpha band. Check the gdalinfo
output of the destination file TEST.tif
On Thu, Nov 3, 2011 at 3:15 PM, Jan Tappenbeck <tappenbeck at widemann.de>wrote:
> hi !
> i had transform some tif-files by epsg-code so the images will rotate and
> at the border now some black triangles.
> now i want to merge by gdalwarp and i use following command with the
> dstalpha-option:
> C:\Program Files (x86)\FWTools2.4.7>gdalwarp -dstalpha[Path]\geotiff\trans_
> **a.tif [Path]OP\geotiff\t
> rans_b.tif [Path]OP\geotiff\TEST.tif
> Creating output file that is 20382P x 10788L.
> Processing input file [Path]OP\geotiff\trans_a.tif.
> 0...10...20...30...40...50...**60...70...80...90...100 - done.
> Processing input file [Path]OP\geotiff\trans_b.tif.
> here are some image-information:
> C:\Program Files (x86)\FWTools2.4.7>gdalinfo [Path]
> Driver: GTiff/GeoTIFF
> Files: [Path]OP\geotiff\trans_a.tif
> Size is 10390, 10390
> Coordinate System is:
> PROJCS["DHDN / 3-degree Gauss-Kruger zone 2",
> GEOGCS["DHDN",
> DATUM["Deutsches_**Hauptdreiecksnetz",
> SPHEROID["Bessel 1841",6377397.155,299.**1528128000009,
> AUTHORITY["EPSG","7004"]],
> AUTHORITY["EPSG","6314"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.**0174532925199433],
> AUTHORITY["EPSG","4314"]],
> PROJECTION["Transverse_**Mercator"],
> PARAMETER["latitude_of_origin"**,0],
> PARAMETER["central_meridian",**6],
> PARAMETER["scale_factor",1],
> PARAMETER["false_easting",**2500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","31466"]]
> Origin = (2601576.178792405400000,**5477422.986974134100000)
> Pixel Size = (0.200049845331526,-0.**200049845331526)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 2601576.179, 5477422.987) ( 7d24'1.33"E, 49d25'34.75"N)
> Lower Left ( 2601576.179, 5475344.469) ( 7d23'59.41"E, 49d24'27.48"N)
> Upper Right ( 2603654.697, 5477422.987) ( 7d25'44.45"E, 49d25'33.49"N)
> Lower Right ( 2603654.697, 5475344.469) ( 7d25'42.50"E, 49d24'26.22"N)
> Center ( 2602615.438, 5476383.728) ( 7d24'51.92"E, 49d25'0.49"N)
> Band 1 Block=10390x1 Type=Byte, ColorInterp=Red
> Band 2 Block=10390x1 Type=Byte, ColorInterp=Green
> Band 3 Block=10390x1 Type=Byte, ColorInterp=Blue
> could someone tell me how to make the black triangel transparenzy ?
> when i move the mousemarker over the black triangle in the OpenEV-Viewer
> in the statusline 0,0,0 will show.
> regards Jan :-)
> FWTools2.4.7 in use by win7
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111103/3533ff9f/attachment.html
