[gdal-dev] include paths and cmake
Garrett Potts
potts at cfl.rr.com
Fri Nov 4 10:20:20 EDT 2011
Hello All:
For include paths of the form gdal/cpl_config.h would lead easier to do MAC Framworks where one can create a gdal.framework and use the gdal/ convention.
Take care
Garrett
On Nov 3, 2011, at 5:24 PM, David Burken wrote:
> Mateusz,
> Just wondering if you've thought about namespacing the include paths? That is:
> #include "cpl_config.h"
> #include "gdal_frmts.h"
> Becomes:
> #include <gdal/port/cpl_config.h>
> #include <gdal/gcore/gdal_frmts.h>
> Or (flattened):
> #include <gdal/cpl_config.h>
> #include <gdal/gdal_frmts.h>
> This would make installs / uninstalls cleaner. Say your install prefix is:
> /usr/local
> Then your includes go to:
> /usr/local/include/gdal
> Instead of straight to:
> /usr/local/include
> I realize this would be a big change. Just thought since you're taking the plunge on cmake it's something to consider.
> Take care,
> Dave
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
