[gdal-dev] Strange behavior of gdalwarp with -overwrite option
Alexander Bruy alexander.bruy at gmail.com
Tue Nov 8 13:07:11 EST 2011
Hi all,
in gdalwarp documentation [0] listed option "-overwrite" with next description:
-overwrite:
    (GDAL >= 1.8.0) Overwrite the target dataset if it already exists.
But when I try to reproject image using next command
gdalwarp -t_srs EPSG:4326 -overwrite mosaic.tif mosaic.tif
i get next error
Creating output file that is 9122P x 2341L.
ERROR 4: `mosaic.tif' not recognised as a supported file format.
and mosaic.tif becomes 8 bytes size file (seems only tif header).
Is this bug or I misunderstand -overwrite option usage?
Tested on Slackware 13.37, GDAL 1.8.1, released 2011/07/09.
[0] http://www.gdal.org/gdalwarp.html
Thanks
Alexander Bruy
