[gdal-dev] Anyone compile the ruby bindings for Ruby 1.9.x?
Ethan Alpert
ealpert at digitalglobe.com
Wed Nov 9 16:04:14 EST 2011
It seems in Ruby 1.9.x the way of determining where the ruby.h file has
changed.
I ran into an identical problem trying to build Geos yesterday and now
I've hit it in GDAL.
In swig/ruby/RubyMakefile.mk
There's the following line;
RubyMakefile.mk:RUBY_INCLUDE_DIR := $(shell ruby -rrbconfig -e "puts
Config::CONFIG['archdir']")
The ruby config now uses the class RbConfig and the attribute rubyhdrdir
is now used in stead of archdir.
I changed the line to the following
RbConfig::CONFIG['rubyhdrdir']")
But it appears that more has changed with the include file structure in
Ruby 1.9.x
Has anyone successfully build the ruby bindings?
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111109/d5c61ff8/attachment.bin
