[gdal-dev] Does SetSpatialFilter use spatial indexes (.qix) for shapefiles
Even Rouault even.rouault at mines-paris.org
Mon Nov 14 13:23:06 EST 2011
Le lundi 14 novembre 2011 18:17:38, Ethan Alpert a écrit :
> Curious if the Shapefile driver uses .qix files if they're available
> when performing SetSpatialFitler.
Ethan,
Quoting http://gdal.org/ogr/drv_shapefile.html :
The spatial indexing uses the same .qix quadtree spatial index files that are
used by UMN MapServer. [...]. Spatial indexing can accelerate spatially
filtered passes through large datasets to pick out a small area quite
dramatically.
Best regards,
Even
