[gdal-dev] Reading SRTM30 grids 'at distance'
Even Rouault
even.rouault at mines-paris.org
Mon Nov 14 13:54:07 EST 2011
Le lundi 14 novembre 2011 18:23:23, Joaquim Luis a écrit :
> Hi,
> I made a nice little tool for Mirone where one can very easily mosaic
> either several flavors of SRTM grids or satellite images from Bing servers.
> My question is about the SRTM30 grids (30 arc minutes) that are
> available here (SRTM plus)
> ftp://topex.ucsd.edu/pub/srtm30_plus/srtm30/data/
> which I would like to be able to access directly with the vsicurl
> mechanism. The trouble in this case is that those grids are raw files
> without any header file. When we have them on disk the simple solution
> is to create a esri .hdr header from the information extracted from the
> file name. However, this logic does not work for files seating in the
> Web because the file and the header won't be located next to each other.
> The same occurs if one has those files compressed. In this case the
> header file cannot be assumed to be stored inside the .zip file and the
> vsizip mechanism will fail for exactly the same reason.
> My question is than, if there is a mechanism to send the header info to
> the GDAL library and thus pretend that file and header leave side by
> side? Note that I want to do this programmatically so need for an
> already existing ready to use solution.
One way to do this is to use the capability of VRT files to describe raw files (
http://www.gdal.org/gdal_vrttut.html ), that offer similar capabilities than
the EHdr header.
For e020n40.Bathymetry.srtm, a quick test shows that the following should do :
<VRTDataset rasterXSize="4800" rasterYSize="6000">
<SRS>GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]</SRS>
<GeoTransform>20, 0.008333333333333, 0.0, 40, 0.0,
-0.008333333333333</GeoTransform>
<VRTRasterBand dataType="Int16" band="1" subClass="VRTRawRasterBand">
<SourceFilename
relativetoVRT="0">/vsicurl/ftp://topex.ucsd.edu/pub/srtm30_plus/srtm30/data/e020n40.Bathymetry.srtm</SourceFilename>
<ImageOffset>0</ImageOffset>
<PixelOffset>2</PixelOffset>
<LineOffset>9600</LineOffset>
<ByteOrder>MSB</ByteOrder>
</VRTRasterBand>
</VRTDataset>
(I've attached it to avoid line wrapping problems)
> Thanks
> Joaquim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
<SRS>GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]</SRS>
<GeoTransform>20, 0.008333333333333, 0.0, 40, 0.0, -0.008333333333333</GeoTransform>
<SourceFilename relativetoVRT="0">/vsicurl/ftp://topex.ucsd.edu/pub/srtm30_plus/srtm30/data/e020n40.Bathymetry.srtm</SourceFilename>
</VRTRasterBand>
</VRTDataset>
