[gdal-dev] access attribute (non-spatial) data in .mdb with PGeo
Driver
Even Rouault
even.rouault at mines-paris.org
Mon Nov 14 15:02:30 EST 2011
Le lundi 14 novembre 2011 20:44:35, Eli Adam a écrit :
> Hi all,
> On Windows, I'm trying to access non-spatial tables in an .mdb file.
> With --debug on I see that the absence of a 'GDB_GeomColumns' table is
> the problem.
> >ogrinfo --debug on Surveys.mdb
> PGeo: EstablishSession(DRIVER=Microsoft Access Driver
> (*.mdb);DBQ=Surveys.mdb) ODBC: SQLDriverConnect(DRIVER=Microsoft Access
> Driver (*.mdb);DBQ=Surveys.mdb) PGEO: SELECT on GDB_GeomColumns fails,
> perhaps not a personal geodatabase? [Microsoft][ODBC Microsoft Access
> Driver] The Microsoft Jet database engine cann ot find the input table or
> query 'GDB_GeomColumns'. Make sure it exists and tha t its name is
> spelled correctly.
> ODBC: SQLDisconnect()
> I noticed this fairly recent commit, which seems to indicate that this
> is the desired behavior, http://trac.osgeo.org/gdal/changeset/21550
I'm confused because if you get to the point of having the trace " PGEO:
SELECT on GDB_GeomColumns fails, perhaps not a personal geodatabase?" it means
that you got after the test of r21550 (which should have discared this mdb as
having no GDB_GeomColumns table), so I highly suspect you are not using trunk
version for this test.
r21550 only enforces what existed before : the PGeo driver can only handle
PGeo MDBs. The new test was introduced specifically to avoid the PGeo driver to
try opening a MDB that should be recognized by the Geomedia driver (new in
trunk).
> I was able to access the non-spatial attributes by making a
> 'GDB_GeomColumns' table and falsely populating it (and ignoring the
> missing 'GDB_SpatialRefs' table errors).
> TableName FieldName ShapeType ExtentLeft ExtentBottom ExtentRight
ExtentTop
> IdxOriginX IdxOriginY IdxGridSize SRID HasZ HasM
> Survey Shape 4 7255394.59721669 241841.239197335 7396378.9177745
524650.46
> 1230004 0 0 141508.958339791 1 0 0
> >ogrinfo -so Surveys.mdb Survey
> ERROR 1: 'SELECT srtext FROM GDB_SpatialRefs WHERE srid = 1' failed.
> [Microsoft][ODBC Microsoft Access Driver] The Microsoft Jet database engine
> cann ot find the input table or query 'GDB_SpatialRefs'. Make sure it
> exists and tha t its name is spelled correctly.
> INFO: Open of `Surveys.mdb'
> using driver `PGeo' successful.
> Layer name: Survey
> Geometry: Unknown (any)
> Feature Count: 20790
> Extent: (7255394.597217, 241841.239197) - (7396378.917775, 524650.461230)
> Layer SRS WKT:
> (unknown)
> Geometry Column = Shape
> DocumentName: String (25.0)
> SurveyDate: DateTime (19.0)
> If the general case requires a 'GDB_GeomColumns' table, could no
> 'GDB_GeomColumns' table be made a driver config option?
Why not using the generic ODBC driver for that use case ?
> I noticed that the new Access MDB driver,
> http://gdal.org/ogr/drv_mdb.html , does not require a GDB_GeomColumns
> table (tested on ubuntu 10.04 and gdal trunk).
Yes, it can understand PGeo MDBs, Geomedia MDBs and generic MDBs.
> Thanks, Eli
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
