[gdal-dev] Re: GDAL GML driver and .xsd schema mapping
    Jukka Rahkonen
    jukka.rahkonen at mmmtike.fi
    Mon Nov 14 16:46:49 EST 2011
Even Rouault <even.rouault <at> mines-paris.org> writes:
> Jukka,
> Hopefully the following should be enough :
> r23378 /trunk/gdal/ogr/ogrsf_frmts/gml/ogrgmldatasource.cpp: GML: add debug
information to know if we use/generate .gfs file while there's a .xsd we ignore
> I'm not sure it is a good idea to make it more verbose than a debug trace.
Thanks, it will be enough for me. I am awaiting samples of other ready defined
Inspire data products, they can be more painful than this authorative units
dataset which has after all rather simple structure.
-Jukka Rahkonen-
