[gdal-dev] can not debug gdal1.8.1 at visual studio 2008
Dan Homerick
danhomerick at gmail.com
Wed Nov 16 09:46:10 EST 2011
The message you're seeing is because Microsoft doesn't include debug
information for their ODBC driver. This should not prevent you from
debugging entirely, it should just mean that you can't step into ODBC
function calls. If you can't debug at all, then the cause is almost
certainly something besides that message.
- Dan
On Wed, Nov 16, 2011 at 3:47 AM, mrym <meryemvrl at gmail.com> wrote:
> Hi,
> i've downloaded gdal1.8.1 and builded it with
> nmake /f makefile.vc DEBUG=1
> nmake /f makefile.vc install
> nmake /f makefile.vc devinstall
> everything was fine till trying to debug gdal functions. i can't debug any
> gdal function. i tried lots of thing(in fact everything in google) to fix
> it, but it's still same. i see this message at output window "
> 'C:\Windows\SysWOW64\odbcint.dll', Binary was not built with debug
> information. " . i got stuck:( please i need your help.
> Thanks..
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/can-not-debug-gdal1-8-1-at-visual-studio-2008-tp7000116p7000116.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
