[gdal-dev] Ogr2ogr
Fred Jones fredjonze at gmail.com
Thu Nov 17 12:34:37 EST 2011
Here is ogrinfo returned:
INFO: Open of
`MSSQL:server=ELMER;database=HT_2011_10;trusted_connection=yes'
      using driver `MSSQLSpatial' successful.
Here is my revised command:
ogr2ogr -overwrite -s_srs EPSG:32002 -t_srs EPSG:4326 -f MSSQLSpatial
"MSSQL:server=ELMER;database=CENSUS_2010;trusted_connection=yes"
"MSSQL:server=ELMER;database=HT_2011_10;trusted_connection=yes;tables=dbo.qaBtcSubLocs(xloc),dbo.qaBtcSubLocs(yloc)"
-sql "SELECT xloc,yloc, spid FROM  dbo.qaBtcSubLocs" -nln "btcSubLocs"
And here are the errors produced:
ERROR 1: Column type float is not supported for geometry column.
Thx for your help. I've read every article I can google, but just haven't
found the right combination of flags to get this to work.
Fred
On Thu, Nov 17, 2011 at 9:35 AM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Fred,
> Check if your source table is being read correctly.
> Use ogrinfo.
> ogrinfo -al "MSSQL:server=ELMER;database=HT_2011_10;trusted_connection=yes"
> OGR doesn't read the MSSQL geometries if the source table doesn't have an
> entry in the geometry_columns table. You can bypass this by using the
> 'Tables' parameter in the connection string[1].
> [1]: http://www.gdal.org/ogr/drv_mssqlspatial.html
>   On Thu, Nov 17, 2011 at 9:28 PM, Fred Jones <fredjonze at gmail.com> wrote:
>>   This is what I have so far. Back to where I started. The table is
>> created in CENSUS_2010 spatial database, but the ogr_geometry column is
>> null. No error.
>> "MSSQL:server=ELMER;database=CENSUS_2010;;trusted_connection=yes"
>> "MSSQL:server=ELMER;database=HT_2011_10;trusted_connection=yes" -sql
>> The geometry_columns table is:
>> f_table_catalog f_table_schema f_table_name f_geometry_column coord_dimension srid geometry_type
>> CENSUS_2010     dbo      btcsublocs      ogr_geometry      2
>> 4326        GEOMETRY
>> Fred
>> On Thu, Nov 17, 2011 at 1:48 AM, Luca Sigfrido Percich <
>> sigfrido at tiscali.it> wrote:
>>> Hi Fred,
>>> Il giorno mer, 16/11/2011 alle 10.11 -0700, Fred Jones ha scritto:
>>> > Hi Sig,
>>> > I have a SQL table temp_sublocs_btc with the MT State Plane x and y as
>>> > the first columns in the table. CENSUS_2010 is a sql spatial database.
>>> > This is the command I have so far. When I execute it, I just get the
>>> > help returned, no error:
>>> > ogr2ogr -overwrite -s_srs EPSG:32100 -t_srs EPSG:4326 -f
>>> "MSSQL:server=ELMER;database=HT_2010_10;tables=temp_sublocs_btc;trusted_connection=yes"
>>> > What am I doing wrong?
>>> Please remember to always post the error messages otherwise we won't be
>>> able to understand. Before the usege text you should see an error
>>> message.
>>> I never worked with ogr and MSSQL, but I guess that the problem is that
>>> you should separate the output format specification (-f "MSSQL")  and
>>> the server connection string.
>>> Try:
>>> ogr2ogr -overwrite -s_srs EPSG:32100 -t_srs EPSG:4326 -f "MSSQL"
>>> assuming that tables=temp_sublocs_btc allows you to select the input
>>> layer.
>>> Regarding the creation of point, in PostGIS I would simply insert the X
>>> and Y coords in two float fields of the target table, and issue a
>>> update CENSUS_2010.temp_sublocs_btc set geom =
>>> ST_Transform(ST_SetSRID(ST_MakePoint(x, y), 32100), 4326)
>>> Which means create a point with x, y, set its SRID to state plane, then
>>> transform it into WGS84, then store it in the geom column of your table
>>> (the geometry column of which should have been created in WGS84 SRS).
>>> I don't know the corresponding function in MSSQL for ST_MakePoint etc...
>>> you should refer to the documentation
>>> I never tried this! I don't know if you can do the transformation
>>> directly with the -sql clause of ogr2ogr or with other options, please
>>> try and let us know.
>>> Sig
>>> _____________
>>> PRIVACY
>>> Le informazioni contenute in questo messaggio sono riservate e
>>> confidenziali. Il loro utilizzo e' consentito esclusivamente al
>>> destinatario del messaggio, per le finalità indicate nel messaggio stesso.
>>> Qualora Lei non fosse la persona a cui il presente messaggio è destinato,
>>> La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o
>>> stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente.
>>> Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla
>>> legislazione europea (Direttiva 2002/58/CE).
>>> PRIVACY
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111117/645fd586/attachment-0001.html
