[gdal-dev] Ogr2ogr
Fred Jones
fredjonze at gmail.com
Thu Nov 17 13:33:50 EST 2011
There is a GEOGRAPHY::STGeomFromText('POINT(x,y)', srid) function in sql
server spatial. However, when I issue the command:
ogr2ogr -overwrite -s_srs EPSG:32002 -t_srs EPSG:4326 -f MSSQLSpatial
"MSSQL:server=ELMER;database=CENSUS_2010;trusted_connection=yes"
"MSSQL:server=ELMER;database=HT_2011_10;trusted_connection=yes" -sql
"SELECT geometry::STGeomFromText('POINT(xloc,yloc)',0) as ogr_geometry,
xloc,yloc, spid FROM dbo.qaBtcSubLocs" -nln "btcSubLocs"
I get the error:
ERROR 1: [Microsoft][ODBC SQL Server Driver][SQL Server]A .NET Framework
error occurred during execution of user-defined routine or aggregate
"geometry":
System.FormatException: 24141: A number is expected at position 10 of the
input.
The input has xloc.
System.FormatException: at
Microsoft.SqlServer.Types.OpenGisWktReader.RecognizeDouble()
at Microsoft.SqlServer.Types.OpenGisWktReader.ParsePointText(Boolean
parseParentheses)
at Microsoft.SqlServer.Types.OpenGisWktReader.ParseTaggedText(OpenGisType
I'd like to keep this as a single command becuase this will be issued on a
server and I don't have local access to write files out under the sql agent
perms (long story about IT security restrictions).
Any ideas?
Fred
On Thu, Nov 17, 2011 at 10:58 AM, Chaitanya kumar CH <chaitanya.ch at gmail.com
> wrote:
> Fred,
> Now I see the problem.
> Your columns xloc and yloc are not really geometry columns. They are just
> a part of the point geometry. We need to make a geometry out of them.
> If it was PostGIS, I would have just used the ST_GeomFromText() function
> to combine those two columns into a point geometry.
> I don't know if such a function exists in MSSQL. So I suggest you convert
> the whole database into another format like CSV, tweak it to make
> geometries from the points, and finally load it into a new table. The CSV
> driver page[1] shows how to convert the x and y values into point
> geometries.
> First run the following command.
> ogr2ogr -f CSV qaBtcSubLocs.csv
> "MSSQL:server=ELMER;database=HT_2011_10;trusted_connection=yes;tables=dbo.qaBtcSubLocs(xloc),dbo.qaBtcSubLocs(yloc)"
> -sql "SELECT xloc,yloc, spid FROM dbo.qaBtcSubLocs"
> Now create qaBtcSubLocs.vrt as described in the driver page but without
> the LayerSRS element.
> Finally run the following command.
> CENSUS_2010;trusted_connection=yes" qaBtcSubLocs.vrt -nln "btcSubLocs"
> [1]: http://www.gdal.org/ogr/drv_csv.html
> On Thu, Nov 17, 2011 at 11:04 PM, Fred Jones <fredjonze at gmail.com> wrote:
>> Here is ogrinfo returned:
>> INFO: Open of
>> `MSSQL:server=ELMER;database=HT_2011_10;trusted_connection=yes'
>> using driver `MSSQLSpatial' successful.
>> Here is my revised command:
>> -sql "SELECT xloc,yloc, spid FROM dbo.qaBtcSubLocs" -nln "btcSubLocs"
>> And here are the errors produced:
>> ERROR 1: Column type float is not supported for geometry column.
>> Thx for your help. I've read every article I can google, but just haven't
>> found the right combination of flags to get this to work.
>> Fred
>> On Thu, Nov 17, 2011 at 9:35 AM, Chaitanya kumar CH <
>> chaitanya.ch at gmail.com> wrote:
>>> Fred,
>>> Check if your source table is being read correctly.
>>> Use ogrinfo.
>>> ogrinfo -al
>>> OGR doesn't read the MSSQL geometries if the source table doesn't have
>>> an entry in the geometry_columns table. You can bypass this by using the
>>> 'Tables' parameter in the connection string[1].
>>> [1]: http://www.gdal.org/ogr/drv_mssqlspatial.html
>>> On Thu, Nov 17, 2011 at 9:28 PM, Fred Jones <fredjonze at gmail.com>wrote:
>>>> This is what I have so far. Back to where I started. The table is
>>>> created in CENSUS_2010 spatial database, but the ogr_geometry column is
>>>> null. No error.
>>>> "MSSQL:server=ELMER;database=CENSUS_2010;;trusted_connection=yes"
>>>> The geometry_columns table is:
>>>> f_table_catalog f_table_schema f_table_name f_geometry_column coord_dimension srid geometry_type
>>>> CENSUS_2010 dbo btcsublocs ogr_geometry 2
>>>> 4326 GEOMETRY
>>>> Fred
>>>> On Thu, Nov 17, 2011 at 1:48 AM, Luca Sigfrido Percich <
>>>> sigfrido at tiscali.it> wrote:
>>>>> Hi Fred,
>>>>> Il giorno mer, 16/11/2011 alle 10.11 -0700, Fred Jones ha scritto:
>>>>> > Hi Sig,
>>>>> > I have a SQL table temp_sublocs_btc with the MT State Plane x and y
>>>>> as
>>>>> > the first columns in the table. CENSUS_2010 is a sql spatial
>>>>> database.
>>>>> > This is the command I have so far. When I execute it, I just get the
>>>>> > help returned, no error:
>>>>> > ogr2ogr -overwrite -s_srs EPSG:32100 -t_srs EPSG:4326 -f
>>>>> "MSSQL:server=ELMER;database=HT_2010_10;tables=temp_sublocs_btc;trusted_connection=yes"
>>>>> > What am I doing wrong?
>>>>> Please remember to always post the error messages otherwise we won't be
>>>>> able to understand. Before the usege text you should see an error
>>>>> message.
>>>>> I never worked with ogr and MSSQL, but I guess that the problem is that
>>>>> you should separate the output format specification (-f "MSSQL") and
>>>>> the server connection string.
>>>>> Try:
>>>>> ogr2ogr -overwrite -s_srs EPSG:32100 -t_srs EPSG:4326 -f "MSSQL"
>>>>> assuming that tables=temp_sublocs_btc allows you to select the input
>>>>> layer.
>>>>> Regarding the creation of point, in PostGIS I would simply insert the X
>>>>> and Y coords in two float fields of the target table, and issue a
>>>>> update CENSUS_2010.temp_sublocs_btc set geom =
>>>>> ST_Transform(ST_SetSRID(ST_MakePoint(x, y), 32100), 4326)
>>>>> Which means create a point with x, y, set its SRID to state plane, then
>>>>> transform it into WGS84, then store it in the geom column of your table
>>>>> (the geometry column of which should have been created in WGS84 SRS).
>>>>> I don't know the corresponding function in MSSQL for ST_MakePoint
>>>>> etc...
>>>>> you should refer to the documentation
>>>>> I never tried this! I don't know if you can do the transformation
>>>>> directly with the -sql clause of ogr2ogr or with other options, please
>>>>> try and let us know.
>>>>> Sig
>>>>> _____________
>>>>> PRIVACY
>>>>> Le informazioni contenute in questo messaggio sono riservate e
>>>>> confidenziali. Il loro utilizzo e' consentito esclusivamente al
>>>>> destinatario del messaggio, per le finalità indicate nel messaggio stesso.
>>>>> Qualora Lei non fosse la persona a cui il presente messaggio è destinato,
>>>>> La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o
>>>>> stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente.
>>>>> Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla
>>>>> legislazione europea (Direttiva 2002/58/CE).
>>>>> PRIVACY
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> +91-9494447584
>>> 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111117/feb3560b/attachment-0001.html
