[gdal-dev] Problem joining a shapefile and MDB
Even Rouault
even.rouault at mines-paris.org
Fri Nov 18 14:19:49 EST 2011
Le vendredi 18 novembre 2011 20:14:42, boesiii a écrit :
> I am trying to join a shapefile and MDB using the following command:
> ogrinfo -sql "SELECT * FROM PLOTS LEFT JOIN
> 'ODBC:geoplan,County_Taxid_Parcels'.County_Taxid_Parcels ON
> PLOTS.SHRT_TXID=County_Taxid_Parcels.SHRT_TXID"
> D:\ms4w\apps\ftmagisapp_v2\maps\background\PLOTS.shp
> The ogrinfo command says it opens the shapefile but then it immediately
> crashes.
> What could be causing it to crash?
> I ultimately will be using this inside a MapServer map file to display
> owner names from the MDB.
You didn't mention which GDAL version you are using. But if it is 1.8.0, then
you probably have hit http://trac.osgeo.org/gdal/ticket/4112 that has been
fixed in 1.8.1
> Thanks.
> http://osgeo-org.1803224.n2.nabble.com/Problem-joining-a-shapefile-and-MDB
> -tp7009404p7009404.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
