[gdal-dev] VSI issue
Frank Broniewski brfr at metrico.lu
Mon Nov 21 03:28:56 EST 2011
Am 20.11.2011 10:04, schrieb Ari Jolma:
> On 11/19/2011 04:24 PM, Even Rouault wrote:
>>> I found the problem. It is changeset 23022 (by you, Even :), which
>>> removes support for "stdout" and adds "/dev/stdout" as an alias to
>>> "/vsistdout/". Simple, but took me a while to find out especially as the
>>> log message begins "mentions in the doc".
>> Hum, so it means that under your CGI the stdout file is actually closed.
>> Because before r23022 /dev/stdout was considered as a regular file and
>> was
>> opened, but now that /vsistdout/ is used, it directly writes to FILE*
>> stdout.
>> I don't know Apache but perhaps there's an option to leave stdout
>> opened for
>> the forked process ?
> I think the correct thing to do is to use "/vsistdout/" in CGI programs,
> since it works both in older (1.8.0) and newer GDAL (next release).
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I can only speak for python, but I agree with Ari here. Mod_wsgi, the
python - apache module advises also not to use /dev/stdout because it is
used internally to communicate with the webserver, [1] holds more
explanation on the issue.
And I don't know, how far you could use /dev/stdout in threaded
environments like a webserver without having more than one thread
writing to the same /dev/stdout.
Just my additional 2 cents on the stdout - issue ;-)
Frank
[1]
http://code.google.com/p/modwsgi/wiki/ApplicationIssues#Writing_To_Standard_Output
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
