[gdal-dev] CopyLayer oddity using GML driver
Even Rouault
even.rouault at mines-paris.org
Mon Nov 21 13:57:23 EST 2011
Le lundi 21 novembre 2011 11:20:33, Ari Jolma a écrit :
> Hi,
> I'm making a new GML layer from an existing layer. For some reason the
> CopyLayer method leaves adjusted fields out but CreateField,
> CreateFeature sequence does not. I guess they should be identical?
> i.e.
> my $datasource = Geo::OGR::Open('Pg:...');
> my $l = $datasource->ExecuteSQL('...');
> my $gml = Geo::OGR::Driver('GML')->Create('/vsistdout/');
> $gml->CopyLayer($l, 'a');
> leaves fields like "a b" out, while
I guess it is because the GML driver transforms "a b" into "a_b" to make it a
valid XML name. But the implementation of CopyLayer() uses SetFrom(), which
cannot guess that "a b" values from source feature should be mapped to "a_b"
of target feature.
> my $l2 = $gml->CreateLayer('test');
> my $d = $l->GetLayerDefn;
> for (0..$d->GetFieldCount-1) {
> my $f = $d->GetFieldDefn($_);
> $l2->CreateField($f);
> $l->ResetReading;
> while (my $f = $l->GetNextFeature) {
> $l2->CreateFeature($f);
> works ok (and prints out warnings about the field name adjustments)
Works ok perhaps, but it is potentially risky. You should not use $l2-
>CreateFeature($f) with $f being a feature that has the feature definition of
$l and not $l2. That could crash in some situations... You're lucky here that
it works for you because you have the same number of fields and same type.
> I tried to look into what the CopyLayer method generic driver does
> differently but could not tell.
CopyLayer() should likely implement the more advanced tricks that ogr2ogr.cpp
uses to do the proprer mapping of field names, even when renames occur.
> Any ideas?
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
