[gdal-dev] Problems with transform raster image - try again !
Jan Tappenbeck
tappenbeck at widemann.de
Fri Nov 25 05:49:00 EST 2011
HI !
i try my translation in use of an other tif-source files!
here even in the tif-header are informations about the reference - worst
coordintes:
C:\Program Files (x86)\FWTools2.4.7>gdalinfo
"D:\City\raster\gas\500\g8746-1_
cit.tif"
Driver: GTiff/GeoTIFF
Files: D:\City\raster\gas\500\g8746-1_cit.tif
Size is 16215, 8904
Coordinate System is `'
Origin = (-948545665.889520530000000,-1021132473.110479500000000)
Pixel Size = (3209.779041131308100,-3209.779041131308100)
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-948545665.890,-1021132473.110)
Lower Left (-948545665.890,-1049712345.693)
Upper Right (-896499098.738,-1021132473.110)
Lower Right (-896499098.738,-1049712345.693)
Center (-922522382.314,-1035422409.402)
Band 1 Block=16215x1 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 255,255,255,255
i create following twf-file manuell:
0.032098
0.000000
0.000000
-0.032098
2586989.395890
5746263.495720
but when i now try to translate by
C:\Program Files (x86)\FWTools2.4.7>gdalwarp -s_srs EPSG:31466 -t_srs
EPSG:25832 "D:\City\raster\gas\500\g8746-1_cit.tif"
"D:\City\raster\gas\500\g8746-1_cit_epsg_utm.tif"
i get following message:
Copying color table from D:\City\raster\gas\500\g8746-1_cit.tif to new file.
Creating output file that is 0P x 0L.
ERROR 1: Attempt to create 0x0 dataset is illegal,sizes must be larger
than zero
did anyone / you have a idea how to translate successfully?
alternative to edit the coordinates manuell in the tif-file?
it is very important for me.
reagrads Jan :-)
